My K&N's foul the cross member on the Harris and I've been thinking about changing to Ram Air foam filters. Can anyone offer any advice/knowledge on the subject - are they any good?
Rod
Alternatives to K&N's
jphaynes669
- ZedHead
I just fitted a set of offset ramair foam filters on my bike. Its a fair bit quieter on induction noise and seems quite responsive. I will hopefully ride it at the weekend so will let you know. I have left the set up as per the k&n, s and dont really expect any glitches.
The foam is fairly thick and at least 2 layers, fitment was good at the neck with decent clips supplied,. You can order in sets of 4 and some sets are priced reduced at the moment.
Got them direct from www.ramair-filters.co.uk
01980 635300 ....paid just under £60.
Jeff.H
- harrythemagnum
I used these Ramair twins on my ZRX, quite cheap off ebay.
http://www.ebay.co.uk/itm/RAMAIR-PERFOR ... 5aeb307565
They are only socks, so you will need some trumpet type things for them to pull over.
What a wonderful philosophy you have,
Magnum1 wrote:jimmock wrote:Magnum,
I had the EXACT same problem.
I cut out the cross member.
The bike runs really nice with the new filters.
Had to get a new hacksaw blade, but got through eventually. Thanks for the tip!
Rod
Rod,
I'm chuffed to fook I was able to help.
I take real pride in my "ability" to see solutions others cannot!
Jimmock.
I hate people I don't like !
jimmock wrote:Magnum1 wrote:jimmock wrote:Magnum,
Rod
Rod,
You guys are so ANAL....
What's wrong with a chisel and hammer
garyd wrote:jimmock wrote:Magnum1 wrote:jimmock wrote:Magnum,
Rod
And pragmatic - the doers of the world
Rod,
jphaynes669 wrote:I just fitted a set of offset ramair foam filters on my bike. Its a fair bit quieter on induction noise and seems quite responsive. I will hopefully ride it at the weekend so will let you know. I have left the set up as per the k&n, s and dont really expect any glitches.
Be interested to know how they run Jeff.
rod
