Engine mounts
Wayne1960
Engine mounts
#1 PostAuthor: Wayne1960 » Sun Mar 30, 2014 8:59 pm
Got the engine back in the frame today. Everything fitted ok but one observation was how close the sump is to the frame on the left. Is that how it should be? If not what could be wrong when it seem to fit ok!
Bike now finished what a joy!
#2 PostAuthor: z1bman » Sun Mar 30, 2014 9:10 pm
how close??
Wayne1960
#3 PostAuthor: Wayne1960 » Sun Mar 30, 2014 9:15 pm
Struggled to get a cloth down the side. It looks ok but wanted yo check.
Wayne1960
#4 PostAuthor: Wayne1960 » Sun Mar 30, 2014 9:50 pm
Also the bottom back bolt is shanked and the shank protrudes past the mount by a good 20mm should there be washers? Just had another look and the engine is as good as touching.
#5 PostAuthor: z1bman » Sun Mar 30, 2014 10:44 pm
have you got the spacer collars in the wright way round in the upper rear engine mount??
Wayne1960
#6 PostAuthor: Wayne1960 » Sun Mar 30, 2014 10:49 pm
I haven't put the spacers in on the upper mounts yet just bolted up the front and the 2 on the bottom of the frame. Pushed the other rear ones in but not bolted up yet.
#7 PostAuthor: z1bman » Sun Mar 30, 2014 11:04 pm
the engine is close to the frame on the l/h side but you need to tighten all the mounting bolts & make sure you have the engine spacers in the wright positions before you decide to panic
Wayne1960
#8 PostAuthor: Wayne1960 » Mon Mar 31, 2014 8:09 am
I have the spacers and they will probably work but they look like they have been made from an old steel bolt.
Does anyone know the correct lengths for these and if they are availble to buy?
#9 PostAuthor: z1bman » Mon Mar 31, 2014 10:41 am
Keefleaf
#10 PostAuthor: Keefleaf » Mon Mar 31, 2014 8:03 pm
I've a pair spare.
P.M. Sending.
Users browsing this forum: Google [Bot] and 33 guests
