Clutch
Clutch
Just fitted the clutch cable to the chain cover housing and all went back together lovely until I adjusted all the cables and when I thought it was good I pulled the clutch and it didn't move. Stripped all back down and it all looks ok!!!
Any ideas?
Any ideas?
Bike now finished what a joy!
adjust the clutch lever adjuster so you can see about 10mm of thread. then screw in the centre cable adjuster all the way so you cannot see any thread. loosen the locking nut on the clutch adjuster in the casing & turn the screw in until it gently touches the push rod. do not over tighten at this point turn the screw back out half a turn & tighten the locking nut. then adjust the centre cable adjuster so you have about 3-5 mm of free play at the lever
- PETER KZ1A
Ok had a good evening with my clutch last night and all is well with a nice smooth action in the clutch lever.
Should I be able to change down and up through the gears? I guessing not without any movement. 1st and neutral select ok.
Also have a annoying squeak very feint but annoying!
Users browsing this forum: No registered users and 219 guests
