Rectifier needed ASAP, got one now, thanks TLC
Mark Tiller
#1 PostAuthor: Mark Tiller » Sat Apr 12, 2014 2:27 pm
Bike let me down this AM....Anyone close to Leighton buzzard got a std rectifier i could buy or borrow or a combined unit they havent yet fitted, cheers...07962421462
07962421462
kawasakichris
#2 PostAuthor: kawasakichris » Sat Apr 12, 2014 2:34 pm
Mark Tiller
#3 PostAuthor: Mark Tiller » Sat Apr 12, 2014 2:44 pm
sorted now I think thanks to TLC
07962421462
Mark Tiller
#4 PostAuthor: Mark Tiller » Sat Apr 12, 2014 5:13 pm
Yup...knackered rectifier, readings all over the place with meter.
I checked the gene and regulator and the readings on those seem OK, im charging the battery now and will check the voltage across the battery when running
07962421462
tlc
#5 PostAuthor: tlc » Sat Apr 12, 2014 5:23 pm
I had an interesting conversation with a very experienced mechanic the other day.
It seems that fitting the newer gel type batteries is not advisable for our older bikes. The explanation being that our generators simply don't output enough for this type of battery.
He has seen it many times before and said they usually fail after a short period, 3000 miles or so.
Garn 1
#6 PostAuthor: Garn 1 » Sat Apr 12, 2014 10:56 pm
Mark, it's usually the regulator that breakdown on these older Kawasaki's. So, before wrapping up, check the voltage across battery at say 3000RPM.
TIC that's interesting. I just had a 12month old "Motobat" fail on me!
I thought the old Z1-Z1000's had alternators that could run a workshop?
RegardZ
Mark Tiller
#7 PostAuthor: Mark Tiller » Sun Apr 13, 2014 8:41 am
Changed the rectifier and its wiring loom, fired it up and 17v across the battery.....bugger, new combined unit on the way.....
07962421462
KeithZ1R
#8 PostAuthor: KeithZ1R » Sun Apr 13, 2014 3:45 pm
When you get it fitted Mark I for one would be very interested on the results you achieve if you don't mind :D
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#9 PostAuthor: chrisu » Sun Apr 13, 2014 3:53 pm
KeithZ1R wrote:When you get it fitted Mark I for one would be very interested on the results you achieve if you don't mind :D
i suspect it'll be like the 4 i've done and be a more reasonable 14.3v.
Garn 1
#10 PostAuthor: Garn 1 » Mon Apr 14, 2014 5:47 am
Agree with Chrisu.... she will be right this time!
BTW that moto battery of mine came good.
REgardZ.
Mark Tiller
#11 PostAuthor: Mark Tiller » Tue Apr 15, 2014 2:39 pm
It arrived today, its a PMC one and came with a whole page of instructions, as a fluent reader of Japenese I had no problems :lol: ...easy to connect with the correct type of plug and bolts where the old rectifier was, works fine, voltage across the battery back to normal...Happy Days
07962421462
KeithZ1R
#12 PostAuthor: KeithZ1R » Tue Apr 15, 2014 3:07 pm
be interested in anybody's experience with the electrex world units ?
Keith
:bop :gom
mistaken.
