Cylinder studs
Cylinder studs
Hi Guyz, does anyone have two short cylinder studs M10 x 158. To replace those damaged during removal on my Z1B. Anything usable will be ok, can replate if not too pitted/corroded
Thanks Dave
Thanks Dave
z1bman wrote:part no 92004- 1002 i a 10mm x 190 stud ? 92004- 1040 is a 10mm x158 stud + they are the same as a z900 a4
if you need to contact cradley 01384 633 455
Just recieved the studs from Cradley. Unfortunately that part Number stud length is actually more like 180mm total.
I think the 158mm length quoted on the parts list and on the discription refers to the length of the stud above the crankcase after it is screwed in.
Users browsing this forum: Bing [Bot] and 33 guests
