DOHC
Get yourself some black enamel paint and brush it in well. Just a thin coat will do as you came go over again after 24 hours.
Then stretch some cotton sheet over a wooden batten and soak with lighter fluid or brake cleaner. Not dripping wet.
Wipe this over the emblem and you will leave all the relieved parts black.
As Chris says, or just paint the black part not worrying too much if you get paint on the letters as because they're raised a little polish on a flat pad will bring the paint off the lettering without touching the black bits...
My old Z1B I did the same on.....
Users browsing this forum: No registered users and 193 guests
