Bloody annoying oil leak...
#1 PostAuthor: chrisNI » Mon May 05, 2014 8:22 pm
Got a small but annoying oil leak at the rev counter drive on my Z1000 - it leaks down the cable then drips off, it's very slight but when you're riding it blows off and goes all over the exhaust downpipes. I'm thinking it's the O ring on the drive, although that's between the head and drive and the oil's getting into the cable not coming out round the edges, so is it possible a worn drive? Anyone had this before and what was it? I guess oil shouldn't be coming out there as there's no O ring to seal the cable?
#2 PostAuthor: z1bman » Mon May 05, 2014 8:31 pm
replace the o ring on the drive housing also the oil seal. make sure the drive gear shaft is perfectly smooth where it comes through the oil seal . fit one of these between the cable & the drive housing
http://www.cmsnl.com/kawasaki-1977-kz65 ... 2f16fldVGQ
#3 PostAuthor: chrisNI » Mon May 05, 2014 8:41 pm
Thanks for that. So there's an oil seal in the drive then guess that's never been changed so probably supect. And that fibre washer that obviously should be there must have been lost years ago :shock:
#4 PostAuthor: z1bman » Mon May 05, 2014 10:11 pm
no fibre washer was never fitted to the z1/900 its used on the z650 but is a good mod the use
#5 PostAuthor: chrisNI » Mon May 05, 2014 11:11 pm
Cool :D Helpful as always :wink:
steve bowdler
#6 PostAuthor: steve bowdler » Tue May 06, 2014 7:24 am
I have been looking at this with the extra seal
http://www.ebay.co.uk/itm/371021916263? ... EBIDX%3AIT
Hinckley
#7 PostAuthor: Hinckley » Tue May 06, 2014 12:13 pm
steve bowdler
#8 PostAuthor: steve bowdler » Tue May 06, 2014 12:32 pm
Hinckley wrote:I'm using one of these - no leaks
https://www.z-power.co.uk/merchantmanag ... ts_id=1134
That is better value , delete the other one from my watch list now :D
#9 PostAuthor: chrisNI » Tue May 06, 2014 8:47 pm
Oil seal, gasket and O ring under £10 posted from ZPower.
Users browsing this forum: No registered users and 193 guests
