Having a nightmare getting fuel tap back on to tank! Don't know why must be doing something wrong.
So I guess I should tighten the nut down onto the fuel tap body then put in the rubber washer then wind the body into the tank.
Tried this but the nut seems to push onto the threaded tube on the tank and won't tighten. Maybe cross threaded but I need to find a solution as the tank is just been re painted!!!!!!!
Is this typical? The thread doesn't look too bad.
Fuel Tap
Thanks for your help. i worked out why i was having a problem and the conclusion is thethread on the tank pipe was worn and the nut simply passed by the threads. I have tried the cold weld glue and it appears to be working.
I have a small black cap with a closed end and 3 holes 2 together and the other oposing.
The cap was in the bag with the petrol tap so i know they belong together.
It fits over the tap union nicely but blocks up some of the holes in the cast alluminium body.
Ak i right in my assumptions and how does it fit. whats it for.
Bike now finished what a joy!
Wayne, That pet-cock always confuses me also! the short end of the tap lever is the pointer end.
With the tap lever pointing to the "O" means On
With the tap turned anti-clockwise 1/4 turn, it is in the "S" posn...... Stop petrol!
Now turn the tap clockwise 1/2 turn thru "O", to "R" this Reserve.
When looking down from the tank riding position, you should see "R" on the tap lever.
Turning back thru "O" to "S", you should read "S" on the tap lever.
You will forget this.... put a dash of red paint on tip of tap lever and S to ensure you know when its off!
Users browsing this forum: No registered users and 175 guests
