Rubber ring
Wayne1960
Rubber ring
#1 PostAuthor: Wayne1960 » Fri May 30, 2014 7:33 am
What goes through the rubber ring that loops round the rear engine mount. Is the battery breather pipe?
Bike now finished what a joy!
steve bowdler
#2 PostAuthor: steve bowdler » Fri May 30, 2014 7:49 am
Carb overflow pipes I think :D
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Fri May 30, 2014 8:12 am
Carb overflow pipes x4
Regards
Steve
Re: Rubber ring
#4 PostAuthor: ZedHead » Fri May 30, 2014 8:14 am
Wayne1960 wrote:What goes through the rubber ring that loops round the rear engine mount. Is the battery breather pipe?
sounds like a cue for Jimmock :roll:
Wayne1960
#5 PostAuthor: Wayne1960 » Fri May 30, 2014 8:18 am
Are these the pipes that connect to the bottom of the float bowls. When I got the bike there was nothing attached to these.
nzphil
#6 PostAuthor: nzphil » Fri May 30, 2014 8:24 am
Yup :D
73 Z1, HondaCRF 450
Most of my money has been spent on Z's, beer & women,
The rest has been squandered.
#7 PostAuthor: z1bman » Fri May 30, 2014 8:36 am
Garn 1
#8 PostAuthor: Garn 1 » Fri May 30, 2014 9:05 am
Guys, speaking of carb overflow tubes,,,,, Anyone seen these two plastic/rubber clips.
I have seen them on several Z's over the years, however, it appears no one else has seen them! They fit perfectly on the four overflow tubes and are obvious by their slightly deformed square look! One fit before the figure-8 rubber strap and one after.
I know I've taken them off a few zeds and I am surprised and embarrassed that I'm the only Zed-nut, that has seen them.
A1John
#9 PostAuthor: A1John » Fri May 30, 2014 10:41 am
Garn , I have these on a couple of my zeds they gather the pipes before they are fed through the rubber ring on the rear upper engine mount.
Wayne1960
#10 PostAuthor: Wayne1960 » Fri May 30, 2014 12:51 pm
So i cant start the bike without them?
#11 PostAuthor: z1bman » Fri May 30, 2014 12:54 pm
its ok to start the bike but only if there is no fuel leaking from the overflow tubes at the bottom of the float bowl's
