Part I'd
Gavin
Part I'd
#1 PostAuthor: Gavin » Mon Mar 10, 2014 9:40 pm
What is this , there is one on my z900 but it wasn't connected up.
http://www.ebay.co.uk/itm/KAWASAKI-Z900 ... 3cdddc7a98
Z1000 MK2
Z1300 DFI
Garn 1
#2 PostAuthor: Garn 1 » Mon Mar 10, 2014 10:01 pm
Gavin, that part is the heat sink for the "hazard switch regulator".
It is connected to the flasher unit, mounted off the battery box.
I don't think I have ever had the need to put my hazard switch on!
Part # 21066-o26 (Z1bman will verify)!
#3 PostAuthor: z1bman » Mon Mar 10, 2014 10:11 pm
it prevents current from back feeding to the instrument lights when the hazard lights are turned on
Wayne1960
#4 PostAuthor: Wayne1960 » Wed Jun 04, 2014 1:38 pm
anyone got a pic of where this fits?
Bike now finished what a joy!
RGH
#5 PostAuthor: RGH » Wed Jun 04, 2014 9:36 pm
Wayne1960
#6 PostAuthor: Wayne1960 » Wed Jun 04, 2014 9:53 pm
Thanks for this. Not sure if it applies to my A4 I can see the indicator relay and I have one of those.
I am still having probs with my hazard switch!
The book says to pull up the hazard switch when ignition is on or in park and the indicators will work.
Mine only work if ignition on and indicator switch turned to the left or right!!
Everything seems ok with all other lights and controls.
Any ideas?
Zed man
#7 PostAuthor: Zed man » Thu Jun 05, 2014 3:54 am
There's also. a Buzzer that should be connected up to it too. have you tested the switch, is it working? I have restored 4 of these so far.. with a repaint of the bracket and knob lettering..
Wayne1960
#8 PostAuthor: Wayne1960 » Thu Jun 05, 2014 5:18 am
Zed man I hope it's working you sold it to me ha ha!
Zed man
#9 PostAuthor: Zed man » Thu Jun 05, 2014 8:49 am
No don't plug it in.... :D
Wayne1960
#10 PostAuthor: Wayne1960 » Fri Jun 06, 2014 11:44 am
Ok thanks for all your help here. i want to get this right and install if i can whats missing.
I have indicators x 4
1 indicator flasher relay
Hazard switch
Am i missing the following and how do i identify them?
Buzzer
Hazard relay 27002-016
Hazard regulator 21066-024
do they fit as the pic above and where does the sounder fit?
steve bowdler
#11 PostAuthor: steve bowdler » Fri Jun 06, 2014 12:28 pm
Hi will have a look to see if I have the hazard relay since i no longer have mine fitted
Wayne1960
#12 PostAuthor: Wayne1960 » Fri Jun 06, 2014 1:13 pm
Thanks Steve.
#13 PostAuthor: z1bman » Fri Jun 06, 2014 3:46 pm
the buzzer fits on to the bottom of the headlight shell with an 8mm bolt
buzzer part no 27040- 002 csm have only got one left in stock $40.50
original hazard relay no longer available but this is identical & much cheaper you will just have to find the rubber that it fits into & is used to mount it on the battery box
http://www.ebay.co.uk/itm/CLASSIC-ROUND ... 4897.l5658
hazard regulator
indicator buzzer
#14 PostAuthor: PAULJAC47 » Fri Jun 06, 2014 4:38 pm
I skipped the buzzer on my A4 and fitted a modern type,the standard one sounds like a srtangled cat on helium bit emabarrasing when you turn up at bike meets :lol:
Looking forward to seeing your bike Wayne after all your hard work,sure it will be worth it.....
Wayne1960
#15 PostAuthor: Wayne1960 » Fri Jun 06, 2014 8:10 pm
Paul thanks for the vote of confidence I must say it does look special. Go out to the garage every night just to look at it.
Hoping to start it tomorrow but see what the weathers like!
Users browsing this forum: No registered users and 172 guests
