Ok Question time...... - this is the first of what will probably be many!
B19 ELR
#76 PostAuthor: B19 ELR » Tue Aug 29, 2006 6:07 am
Kawasaki still do the original ELR Green in touch up form and it would be easy to get a paint supplier to make some up.
uk kev
#77 PostAuthor: uk kev » Wed Aug 30, 2006 9:55 pm
Do any of you have a bigger version, or better picture of this bike, that I can use to get some graphics made up from.
Iain marshall
#78 PostAuthor: Iain marshall » Wed Aug 30, 2006 10:24 pm
Kev dont have many pics of this bike,but i'll see what i can find ;)
(Edited by Iain marshall at 11:34 pm on Aug. 30, 2006)
uk kev
#79 PostAuthor: uk kev » Wed Aug 30, 2006 10:43 pm
thanks Iain, I don't seem to be able to find anything bigger.
london calling
#80 PostAuthor: london calling » Thu Aug 31, 2006 2:57 am
Kev,as mentioned before the KAWASAKI RACERS book has a centre spread picture of Eddie's '81 works racer.
uk kev
#81 PostAuthor: uk kev » Thu Aug 31, 2006 8:24 am
Do you have an ISBN number for the book Jack?
Iain marshall
#82 PostAuthor: Iain marshall » Thu Aug 31, 2006 9:03 am
Merlin books [url=http://www.merlinbooks.com/merlin/kwak.htm
(Edited]http://www.merlinbooks.com/merlin/kwak.htm
(Edited[/url] by Iain marshall at 10:04 am on Aug. 31, 2006)
uk kev
#83 PostAuthor: uk kev » Thu Aug 31, 2006 9:16 am
Thanks for the link....
Next question then....
Oil pressure switch, I can't find it, so taking into consideration that my motor is actually an 84 model year, and not a B1 or B2, would the pressure switch be located in a different place, and not on top of the oil cooler pipe block?
london calling
#84 PostAuthor: london calling » Thu Aug 31, 2006 11:01 am
Kev,as far as i know it's in the same place as B1/B2 and J models.Full info in the base B1/B2 workshop manuals i'd imagine.
Kev,i've listed some uni-trak electrical components on ebay if you're anything for your bike.My sellers name is brokemyneck.
uk kev
#85 PostAuthor: uk kev » Thu Aug 31, 2006 11:06 am
Right another question (I am sorry but who else am I going to ask)
Fuel Tanks,,,,
This is the look I want, and as you can see the tank is much rounder than a GPz1100-B model tank, in fact it is more like a Z650 tank, so would a Z650 tank fit? I know it would need a hole for the fuel gauge underneath, but are there other differences? do any of you have a picture of the underside of a B1 tank?
(Edited by uk kev at 12:07 pm on Aug. 31, 2006)
london calling
#86 PostAuthor: london calling » Thu Aug 31, 2006 12:04 pm
Kev,the tank on the Works racer is a U.S.spec Z1000J1 tank.
The underneath of the B1 is the same as a U.K.spec Z1000J tank but also has the return for the fuel injection.
Try ebay.com for an American Z1000J1 petrol tank.
#87 PostAuthor: Rich » Thu Aug 31, 2006 6:01 pm
Oil pressure switch - ZX1100 A2 it may be on the sump pan underneath the gearbox sprocket. Have a look on http://www.buykawasaki.com/ under "owner info" at the parts book for 1984, the breather cover/oil pan section shows it there.
That's another pint you owe me!
uk kev
#88 PostAuthor: uk kev » Fri Sep 01, 2006 12:30 pm
okely dokely peeps, lets carry on with this meander through the backwoods of my bike.
I opened her up today, well just a little, to see what lies within, and this is the answer...
So is this a good thing to find or a bad thing? and is this a standard Kwaka part, and if so, do we know what Ohms Dyna coils work best with such a beast?
While I was down there looking, I also took some shots of where I think the oil pressure switch should be, but as you can see it aint!
Can someone tell me what the bit is at the top of the picture above the oilway?
And while we are down here, I still have the fuel pump fitted, but obviously not connected, so it will be removed soon, now I am not sure if it works, but it is free if any of you would like it, when it is removed.
uk kev
#89 PostAuthor: uk kev » Fri Sep 01, 2006 12:34 pm
fuel pump
rickman CRR
#90 PostAuthor: rickman CRR » Fri Sep 01, 2006 1:41 pm
Kev, If your looking for ideas to build a replica, how about this....
http://www.supershowevents.com/magazine ... 3hind.html
There are plenty of ELR's about but not many of these perhaps?
