Harris Magnum 2 fork leg length
ruffle
#1 PostAuthor: ruffle » Mon Jun 16, 2014 5:55 pm
Anyone got...
A) A tape measure
B) A Magnum 2 with an 18" front wheel and Marzocchi forks
C) Time to measure from the top of the fork to the axle centre?
TVM.
PJ
#2 PostAuthor: PJ » Mon Jun 16, 2014 7:54 pm
Hi Ruffle,
I have a 1980 Z1R Moto Martin with 18 inch Front Wheel and Marzocchi Forks if that helps???
ruffle
#3 PostAuthor: ruffle » Tue Jun 17, 2014 7:29 am
Thanks but it's really a Harris Magnum 2 I need the info for.
My new project (which will get a thread in the Projects section but at the moment it's all scheming and planning with nothing physical happening) has got a 16" GPz900R front wheel which I'd like to replace with an 18 or 17" jobbie so I can fit decent rubber (16" BT45's are OK but I'd prefer something stickier).
My forks measure ~840mm from top to axle and I suspect they've been built with long stanchions for the 16" wheel as the clipons are above the top yoke.
PJ
#4 PostAuthor: PJ » Tue Jun 17, 2014 7:52 am
I have a Harris also but it is running later suzuki gear
martinz1000r
#5 PostAuthor: martinz1000r » Tue Jun 17, 2014 7:54 am
I have but it's in bits at the moment :(
Marzocchi forks with 18" Astralite. Avon tyre. It's all in bits and at Griff's for refurb.
Long shot but ask Harris directly.
ruffle
#6 PostAuthor: ruffle » Tue Jun 17, 2014 11:23 am
Don't suppose Griff has a tape measure by any chance? :)
I've emailed Harris... wonder if their customer service extends to bikes made 26 years ago that've been through half a dozen owners?
martinz1000r
#7 PostAuthor: martinz1000r » Tue Jun 17, 2014 11:35 am
How accurate do you need it? The stanchions are here. Not sure how much extra the assembled leg would add.
martinz1000r
#8 PostAuthor: martinz1000r » Tue Jun 17, 2014 11:38 am
if it is any help the chrome stanchions are 63cm long
KWACKERZ1
#9 PostAuthor: KWACKERZ1 » Wed Jun 18, 2014 10:27 am
Straight from the horses mouth, Lester Harris told me the chassis were designed for 29 ½ inch length forks with the 18â€￾ wheels and 45mm offset on the yokes.
I also have some of those m1r forks but they are stripped I could tell you the length of the chrome tubes though. If that is any use.
