Thanx Alan
Z1r Float Heights
EGGPIEROE
Z1r Float Heights
hi every one can somebody help me please ? can any one tell me the float heights for a 1980 z1r us import, and do you measure them upside down or the way when they are are on the bike
Thanx Alan
Thanx Alan
Whatever the float height:
Remove bowls.
Invert carbs (thats upside-down to me & you
Take weight off floats until they are only just touching needle valve (by tang)
Now measure from underside of carb body (metal casing where float bowl mates with body) to top of float (as they sit with carbs inverted)
You now have the float height. I think its around 20mm
Do a search as this has been discussed before
Remove bowls.
Users browsing this forum: No registered users and 115 guests
