Regards
Garn 1 wrote:The thicker fins are usually the earlier barrels and as Zmax says, the groove for the o-ring is a reliable indication of the "later than Z1" barrels.
The early models Z1 have a different font of embossing of the "903 cc" to the later ones. The noticeable difference is in the number "3" which has unequal branches and all numbers are larger on the earlier models.
