First Start
fuel system/ fuel level checked with a gauge should have been set up on the bench/vice before they where fitted to the bike. i always leave them in the vice for at least a couple of days to make sure the fuel level doesn't creep up & leak from the overflow pipes. is the fuel tap working as it should?
Just a thought...are you using a slave fuel feed or the main tank...if the main tank have you got the filler cap open? If the breather hole in the cap is blocked the fuel can dribble down to the float bowls but can't really keep up with the demands of a running engine (yes, happened to me yonks ago and took hours to solve).
Z1-B, 360bhp ZX1000NGF
Update
Carbs sorted and fuel levels checked and correct
Valve clearances all set up within tolerances
Compression good now in all 4 cylinders, 1&4 better then 2&3 but not much difference.
Timing checked and looks good and sparking points and plugs
Going to try with petrol cap open
But still not firing
Changed plugs 1 & 4 over but the same
Can smell petrol through plug holes
Urrrrrrghhhhhhhh
What now?
Urrrrrrghhhhhhhh
What now?
Bike now finished what a joy!
Like Mark(Piggy) says make sure you have a good 12volts Dc at the coils with ign on.......sometimes a good spark in air will not be good enough when in the pot and under compression,you are using fresh fuel,ulnleaded seems to go off rapidly these days,you sure chokes are opening? try blocking air intake partly with a rag to simulate choke...
Its the same wire Wayne, the 12 volts come from 12 volt feed via kill switch and feeds both coils! the other side oof the coil low tension side goes to your points,when the points open this causes the coil emf to collapse and discharge high tension voltage to the plugs...
Users browsing this forum: MikeP and 47 guests
