First Start
#76 PostAuthor: z1bman » Tue Jul 08, 2014 7:40 pm
l/h set of points = 1+ 4 should have black wire. r/h points should have green wire = 2+3. l/h coil feeds 1+4 cylinders. lh ht lead from this coil goes to no1 cylinder r/h ht lead from this coil goes to no 4 cylinder. rh coil feeds no 2+3 cylinders the right hand ht lead from this coil goes to no 3 cylinder the l/h ht lead from this coil goes to no 2 cylinder
lh coil = 1+ 4 should have black + yellow with red trace wires connected
r/h coil= 2+3 should have green + yellow with red trace wires connected
Wayne1960
#77 PostAuthor: Wayne1960 » Tue Jul 08, 2014 9:29 pm
Z
All seems ok
I have slightly different colours
12v supply is yellow with red trace with twin connector orange cables going to L/H left coil and L/H right coil
White cables from R/H of left coil going to to black at points feeding 1 & 4 and R/H of right coil going to green at points feeding 2 & 3
So 12v live to left side of both coils and black to left coil and green to right.
Seems ok to me
Bike now finished what a joy!
#78 PostAuthor: z1bman » Tue Jul 08, 2014 10:00 pm
you say in a previous post that when you put your hand over the inlet to the carbs your hand was wet with fuel so it must be sucking fuel into the cylinders. from what you have said the ignition /points & coils are wired & set correctly. are you sure the valve timing is 100% correct? photo's of the valve timing would help with photo's of the end of the camshafts looking from the right hand side as your sitting on the bike . also a photo of the timing advancer on top dead centre 1+4
Wayne1960
#79 PostAuthor: Wayne1960 » Tue Jul 08, 2014 10:05 pm
Ok I will email them
Wayne1960
#80 PostAuthor: Wayne1960 » Tue Jul 08, 2014 10:27 pm
Z sent you pics on email
#81 PostAuthor: PAULJAC47 » Wed Jul 09, 2014 4:30 pm
Wayne stick some pics on here, we are on 6 pages ongoing now for this prob,
it will get sorted, there is a good amount of knowledge on this forum.Paul J
mick znone
#82 PostAuthor: mick znone » Wed Jul 09, 2014 4:34 pm
and i imagine there are many following but not posting so as to not fill the thread up. good luck.
#83 PostAuthor: z1bman » Wed Jul 09, 2014 4:47 pm
it should be running tonight :lol: :lol: :lol:
GEZ635
#84 PostAuthor: GEZ635 » Wed Jul 09, 2014 4:54 pm
Valve timing 2/3 teeth out I reckon.
Gez
P.s it's been a while!
Gez
#85 PostAuthor: PAULJAC47 » Wed Jul 09, 2014 5:16 pm
Bloody hell Gez havent seen you on here for a bit hows it going? if you couldnt sort this out no one could!!!!! you have probably forgot more than most know,all the best mate!...Paulj
PJ
#86 PostAuthor: PJ » Wed Jul 09, 2014 6:32 pm
PAULJAC47 wrote:Bloody hell Gez havent seen you on here for a bit hows it going? if you couldnt sort this out no one could!!!!! you have probably forgot more than most know,all the best mate!...Paulj
That's the trouble - he has forgot!!
How are ya big fella?
Wayne1960
#87 PostAuthor: Wayne1960 » Wed Jul 09, 2014 8:54 pm
Z I sent you pics this evening. Changed timing 180 degrees. Cam lobes facing in as you set up. I am right that if I turn the engine over from TDC 1 & 4 through 180 to TDC 1 & 4 the cam lobes face out again.
Anyway, checked valves again and ok. Put it all back together and same, spins over but not firing.
I know it's going to be something simple.
#88 PostAuthor: z1bman » Wed Jul 09, 2014 9:12 pm
i have looked at your photo & the valve timing looks ok now & yes if you turn the engine 180% the cam lobes will be facing out but the timing mark on the advancer will be on 1&3 have you done anther compression test & what are the readings
#89 PostAuthor: z1bman » Wed Jul 09, 2014 9:32 pm
valve timing before = 180% out
valve timing now
Wayne1960
#90 PostAuthor: Wayne1960 » Wed Jul 09, 2014 9:32 pm
Hi Z I will do another compression test.
I just checked again.
If you set TDC 1&4 with cam lobes facing in as you advised then turn crank until TDC 1&4 come round again the cam lobes face out!
Users browsing this forum: No registered users and 76 guests
