First Start
#91 PostAuthor: z1bman » Wed Jul 09, 2014 9:47 pm
have a look at the locating peg in the crank that locates the advance & retard it might have sheared of ? remove no 4 spark plug & turn the engine over on the crank until the piston comes to the top of its stroke then check that the tdc mark on the advancer is in line with the mark on the cover
Wayne1960
#92 PostAuthor: Wayne1960 » Wed Jul 09, 2014 9:58 pm
Ok sorry to be a dummy but a little lost with that
Bike now finished what a joy!
#93 PostAuthor: z1bman » Wed Jul 09, 2014 10:14 pm
remove the points back plate undo the bolt that holds the advancer to the crank & remove the advancer + you should see a locating peg sticking out of the end of the crank there is a cutaway in the advancer that locates on to the peg
Wayne1960
#94 PostAuthor: Wayne1960 » Wed Jul 09, 2014 10:24 pm
Ok checked piston at TDC and it aligns with timing marks. Too noisy to check compression tonight and not sure about the thing shearing off !
Wayne1960
#95 PostAuthor: Wayne1960 » Wed Jul 09, 2014 10:26 pm
Ok I had this out last week and put some grease in the advancer and it felt like it located ok. Maybe I should check
#96 PostAuthor: z1bman » Wed Jul 09, 2014 10:34 pm
if you have done the tdc check & the advancer lines up i wouldn't bother removing the advancer
steve bowdler
#97 PostAuthor: steve bowdler » Sun Jul 13, 2014 9:31 am
Hi , any updates , hope you have it sorted :D
Wayne1960
#98 PostAuthor: Wayne1960 » Sun Jul 13, 2014 9:36 am
Hi yes got it to run, got some leaks and I think timing issues so trying to sort those.
510racer
#99 PostAuthor: 510racer » Thu Oct 09, 2014 9:37 pm
Wayne1960 wrote:Hi yes got it to run, got some leaks and I think timing issues so trying to sort those.
What was it that finally got it to run???
Big Fluff
#100 PostAuthor: Big Fluff » Fri Oct 10, 2014 7:09 am
I hope it wasn't by putting fuel down the plug holes... :roll: This was suggested 6 pages back!
Wayne1960
#101 PostAuthor: Wayne1960 » Sun Oct 12, 2014 6:47 pm
Hi
I really don't know exactly what changed but she's running ok now. It was pretty much most of the advise I had on here but didn't put fuel in the plug holes.
It is all back to how it should be and running well. I still think it needs some tuning but is seems ok.
