starter probs
sme
starter probs
#1 PostAuthor: sme » Thu Jul 24, 2014 3:43 pm
found there was problems turning the engine over,
not spinning quickly and smoothly,
took left casing off,
what size is the bolt fits to take off the starter clutch rotor on
gpz1100 84.
just noticed inside the rotor magnets are cracked,
can they be fixed or need replacing?
how do i refit the rotor onto the crank again?
sme
#2 PostAuthor: sme » Thu Jul 24, 2014 4:32 pm
just fitted a new battery,
but the engine is still slow to turn over,
can see the starter motor moving slightly.
weaver
#3 PostAuthor: weaver » Thu Jul 24, 2014 4:43 pm
sounds like your starter needs sorting out,the cracked magnets sounds like a separate issue
sme
#4 PostAuthor: sme » Thu Jul 24, 2014 5:46 pm
starter spins as usual when out of engine,
finger test over ports shows no1 cylinder not much compression :x
long term project or break it
steve.w
#5 PostAuthor: steve.w » Thu Jul 24, 2014 5:50 pm
i believe 18mm metric fine is the thread .. the rear wheel spindle fits ..screw it in and give it a donk with hammer :wink:
sme
#6 PostAuthor: sme » Fri Jul 25, 2014 6:19 am
got the rotor off,
the springs and rollers are there,
sme
#7 PostAuthor: sme » Wed Jul 30, 2014 8:14 pm
took starter to bits,
found the connector that leads to the outside was broken,
brushes are good
what else needs checking on the starter motor?
or is there an upgrade that can replace this one?
