gpz1100 uni-trak
snotie1965
gpz1100 uni-trak
#1 PostAuthor: snotie1965 » Thu Jul 24, 2014 2:56 pm
Can anyone advise me on sorting out the anti-dive pipes , the ones that go from the splitter behind the upper fork leg to the top of the anti-dive unit on the front lower part of the fork leg ?
I am sure that i read somewhere that they could be changed to hoses ?
But i went to my local hose place where they make all that type of stuff and he could not find anything suitable ?
steve.w
#2 PostAuthor: steve.w » Thu Jul 24, 2014 5:14 pm
never heard of em being done in braided ..but may be possible ,,why ya wanna change them ??? most people just bypass them ??
snotie1965
#3 PostAuthor: snotie1965 » Thu Jul 24, 2014 6:18 pm
steve.w wrote:never heard of em being done in braided ..but may be possible ,,why ya wanna change them ??? most people just bypass them ??
The bike at present runs re-built anti-dive units and i have progressive fork springs as well ,it works really well But one of my anti-dive tops has a slight weep from where the bleed nipple goes in ,so over time the brake lever gets a bit `spongy`,however "Gus" from this forum sent me 2 old tops but they have a slight angle on them and i do not want to bend the old original pipes to much in-case they fracture !!
I know you can blank the anti-dive units off ,but you need plates made with a groove machined in them ?
ideally i would like to keep the anti-dive all working correctly ?
gpjes
gpz1100 unitrac
#4 PostAuthor: gpjes » Thu Jul 24, 2014 7:23 pm
Hiya, yes it can be done I've worked out how to do it, I was going to do my gpz1000rx in braided, but the anti- dive pipes aren't so bad so I've re-used them, but here's how to do it. There are two ends an if I can remember your model has a concave & convex fitting arrangement, it is a long time ago since I had mine, the RX has convex each end, use venhill fittings to create male ends then carefully measure what length you need and get it made by venhill, go onto venhills own website and bloody great!! it can all be done in stainless yep goodridge do make them but not the bits you need in stainless just plated steel(Crap). So I hope this helps you out, I now make up my own Gauge pipes for pressure washers and they look really good. Hope this helps coz them anti-dive pipes are a deleted part, and yes if you plate them over you need to engrave grooves or else you'll have rock hard forks!!!
More Smiles Per Mile
steve.w
#5 PostAuthor: steve.w » Fri Jul 25, 2014 5:58 am
i have some mint original pipes and antidives off an 1100 .. :wink:
snotie1965
Re: gpz1100 unitrac
#6 PostAuthor: snotie1965 » Fri Jul 25, 2014 11:14 am
gpjes wrote:Hiya, yes it can be done I've worked out how to do it, I was going to do my gpz1000rx in braided, but the anti- dive pipes aren't so bad so I've re-used them, but here's how to do it. There are two ends an if I can remember your model has a concave & convex fitting arrangement, it is a long time ago since I had mine, the RX has convex each end, use venhill fittings to create male ends then carefully measure what length you need and get it made by venhill, go onto venhills own website and bloody great!! it can all be done in stainless yep goodridge do make them but not the bits you need in stainless just plated steel(Crap). So I hope this helps you out, I now make up my own Gauge pipes for pressure washers and they look really good. Hope this helps coz them anti-dive pipes are a deleted part, and yes if you plate them over you need to engrave grooves or else you'll have rock hard forks!!!
Thanks for the info ,i will go onto the Venhill site and see if i can work something out ? cheers Andy ....
snotie1965
#7 PostAuthor: snotie1965 » Fri Jul 25, 2014 2:27 pm
steve.w wrote:i have some mint original pipes and antidives off an 1100 .. :wink:
Are they for sale ?
snotie1965
#8 PostAuthor: snotie1965 » Sun Jul 27, 2014 7:47 pm
Are they for sale ?
Are they for sale ?? :?:
steve.w
#9 PostAuthor: steve.w » Tue Jul 29, 2014 5:31 am
yes :wink: :wink:
Users browsing this forum: No registered users and 134 guests
