Smokey rebore
Dodgy Z1B
Smokey rebore
#1 PostAuthor: Dodgy Z1B » Tue Jul 29, 2014 8:49 am
Would you expect a newly rebored engine to smoke for a while my worry is its a shite rebore job not on my z on an other unmentionable 550 four stroke bike :D the oil scraper rings were a one piece item looked dodgy.
mike_p
#2 PostAuthor: mike_p » Tue Jul 29, 2014 9:42 am
Are you sure it's the rebore & not the valve oil seals ?
#3 PostAuthor: Pigford » Tue Jul 29, 2014 12:36 pm
Run it in with cheap mineral oil - after a couple hundred miles swap for decent mineral or semi & see how it is.
Don't run it in too conservatively - the bores may glaze over :!:
Dodgy Z1B
#4 PostAuthor: Dodgy Z1B » Thu Jul 31, 2014 11:27 am
Thanks valve seals done at same time cheap oil it is wouldn't waste good stuff on it to be honest as it's not a z :D
#5 PostAuthor: chrisu » Thu Jul 31, 2014 4:02 pm
can take a while to bed in - if you've done over 100 miles and its still smoking i'd then be concerned.
Users browsing this forum: No registered users and 137 guests
