Z900 A4 Tank Removal
aljones453
#1 PostAuthor: aljones453 » Sat Jul 05, 2014 11:41 pm
Not really great with mechanicals but before attempting to remove for re-painting, could anyone tell me how best to remove the tank on a Z900A4?
Is it quite straight forward or are there any gotchas I need to look out for?
Thanks in advance from a mechanical luddite!
PJ
#2 PostAuthor: PJ » Sun Jul 06, 2014 7:18 am
Hi Al,
Just remove the fuel pipes and slide the tank backwards and upwards
aljones453
#3 PostAuthor: aljones453 » Sun Jul 06, 2014 7:30 am
PJ wrote:Hi Al,
Thanks PJ, I assume tank comes off with tap so can empy remaining fuel by opening tap. Bone question I am sure.
garyd
#4 PostAuthor: garyd » Sun Jul 06, 2014 7:49 am
aljones453 wrote:
PJ wrote:Hi Al,
Thanks PJ, I assume tank comes off with tap so can empty remaining fuel by opening tap. Bone question I am sure.
That's exactly right, but then remove the tap and make sure all the fuel and genk is removed.
Tonka
#5 PostAuthor: Tonka » Sun Jul 06, 2014 7:59 am
Take the side panel off as you can catch it with the fuel tap when pulling it back - I've only caught it once but that was enough!
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
Z1parR
#6 PostAuthor: Z1parR » Sun Jul 06, 2014 8:12 am
+1 it's very easy to catch the panel :evil:
0172 . Geoff Parr
Mark Tiller
#7 PostAuthor: Mark Tiller » Sun Jul 06, 2014 9:08 am
don't forget to release the rubber strap at the rear of the tank underneath
07962421462
aljones453
#8 PostAuthor: aljones453 » Sun Jul 06, 2014 9:12 am
Mark Tiller wrote:don't forget to release the rubber strap at the rear of the tank underneath
Thanks all. Will have a go using all the advice next w/end if I can go wrong it will but fingers crossed.
Al J
Tonka
#9 PostAuthor: Tonka » Sun Jul 06, 2014 4:22 pm
Oh! Don't forget to switch the fuel tap off before taking the pipes off!
I've never done that though!! :roll: :oops:
aljones453
#10 PostAuthor: aljones453 » Mon Aug 04, 2014 10:01 pm
All, many thanks remove all parts piece of cake with all your tips. Will deliver tank etc to TCP Norwich for tank seal and re-spray on Wed. I can't remember who recommended TCP on the forum, but having contacted Ian at TCP seems sound bloke.
