VM 28 or VM 29s
Lee McEvoy
VM 28 or VM 29s
#1 PostAuthor: Lee McEvoy » Mon Aug 18, 2014 8:56 pm
Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
Thanks :D
Mark Tiller
#2 PostAuthor: Mark Tiller » Mon Aug 18, 2014 9:06 pm
29 smoothbores have this little square casting on the side
07962421462
#3 PostAuthor: Pigford » Mon Aug 18, 2014 9:06 pm
YES
Easy difference is the top cover - the 29's have a "keyhole" shaped top :wink:
z1000puddin
#4 PostAuthor: z1000puddin » Mon Aug 18, 2014 9:20 pm
GOD I AM SLOW AT THIS !!
Lee,
One of the signs of 29mm Smoothbores is if you look on the R/H side on the body just above the float bowl- you will see a small square recess in the body casting.
Zed til Dead
big green bus
#5 PostAuthor: big green bus » Tue Aug 19, 2014 7:03 am
I thought the 29's have a hex nut on the float bowl to get to the main jet instead of a drain screw
snotie1965
Re: VM 28 or VM 29s
#6 PostAuthor: snotie1965 » Tue Aug 19, 2014 10:31 am
Lee McEvoy wrote:Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
Thanks :D
I do not think he meant "smooth bores" :?:
Re: VM 28 or VM 29s
#7 PostAuthor: zed1015 » Tue Aug 19, 2014 11:59 am
Thanks :D
The 29mm only came as smoothbores.
snotie1965
Re: VM 28 or VM 29s
#8 PostAuthor: snotie1965 » Tue Aug 19, 2014 3:05 pm
zed1015 wrote:
Thanks :D
I always thought that GS1000 S used 29 mm ? but it would not be the 1st or last time ive been wrong :oops:
Lee McEvoy
#9 PostAuthor: Lee McEvoy » Tue Aug 19, 2014 5:19 pm
Thanks for those steers. Looks like I have the VM29s :D
Although not sure about the key hole tops pigford talked about.
Sorry about the photo
Lee
#10 PostAuthor: Pigford » Tue Aug 19, 2014 5:42 pm
Image PROPER SMOOTHIES
...................thats what I'm talking about :lol:
jimmock
#11 PostAuthor: jimmock » Tue Aug 19, 2014 5:49 pm
Lee McEvoy wrote:Thanks for those steers. Looks like I have the VM29s :D
Lee
Lee,
I think your engine is in the frame the wrong way??
Jimmock. :wnkr
I hate people I don't like !
Re: VM 28 or VM 29s
#12 PostAuthor: zed1015 » Tue Aug 19, 2014 6:15 pm
snotie1965 wrote:
zed1015 wrote:
Thanks :D
Gs1000 used either 26mm or 28mm slides depending on model before going to CV's.
The 998cc homologation Katana used 32mm smoothbores (the 1100 used CV's)
markz9
smootbores
#13 PostAuthor: markz9 » Wed Aug 20, 2014 11:21 am
i recently got some gs1000 parts and was told 1 set of carbs where off a katana 998cc does the inside of the carb body change into an oval shape rather than staying round all the way through??
mark
Crofty
#14 PostAuthor: Crofty » Wed Aug 20, 2014 6:19 pm
There were some Katana carbs that had oval throats.
Re: smootbores
#15 PostAuthor: zed1015 » Wed Aug 20, 2014 8:20 pm
markz9 wrote:i recently got some gs1000 parts and was told 1 set of carbs where off a katana 998cc does the inside of the carb body change into an oval shape rather than staying round all the way through??
mark
Yes! They are oval at the venturi.
Users browsing this forum: KevH and 38 guests
