VM 28 or VM 29s
Lee McEvoy
VM 28 or VM 29s
#1 PostAuthor: Lee McEvoy » Mon Aug 18, 2014 8:56 pm
Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
Thanks :D
Mark Tiller
#2 PostAuthor: Mark Tiller » Mon Aug 18, 2014 9:06 pm
29 smoothbores have this little square casting on the side
07962421462
#3 PostAuthor: Pigford » Mon Aug 18, 2014 9:06 pm
YES
Easy difference is the top cover - the 29's have a "keyhole" shaped top :wink:
z1000puddin
#4 PostAuthor: z1000puddin » Mon Aug 18, 2014 9:20 pm
GOD I AM SLOW AT THIS !!
Lee,
One of the signs of 29mm Smoothbores is if you look on the R/H side on the body just above the float bowl- you will see a small square recess in the body casting.
Zed til Dead
big green bus
#5 PostAuthor: big green bus » Tue Aug 19, 2014 7:03 am
I thought the 29's have a hex nut on the float bowl to get to the main jet instead of a drain screw
snotie1965
Re: VM 28 or VM 29s
#6 PostAuthor: snotie1965 » Tue Aug 19, 2014 10:31 am
Lee McEvoy wrote:Is there a way of telling the difference (without measuring the insides) between the 28s and 29s?
Thanks :D
I do not think he meant "smooth bores" :?:
Re: VM 28 or VM 29s
#7 PostAuthor: zed1015 » Tue Aug 19, 2014 11:59 am
Thanks :D
The 29mm only came as smoothbores.
snotie1965
Re: VM 28 or VM 29s
#8 PostAuthor: snotie1965 » Tue Aug 19, 2014 3:05 pm
zed1015 wrote:
Thanks :D
I always thought that GS1000 S used 29 mm ? but it would not be the 1st or last time ive been wrong :oops:
Lee McEvoy
#9 PostAuthor: Lee McEvoy » Tue Aug 19, 2014 5:19 pm
Thanks for those steers. Looks like I have the VM29s :D
Although not sure about the key hole tops pigford talked about.
Sorry about the photo
Lee
#10 PostAuthor: Pigford » Tue Aug 19, 2014 5:42 pm
Image PROPER SMOOTHIES
...................thats what I'm talking about :lol:
jimmock
#11 PostAuthor: jimmock » Tue Aug 19, 2014 5:49 pm
Lee McEvoy wrote:Thanks for those steers. Looks like I have the VM29s :D
Lee
Lee,
I think your engine is in the frame the wrong way??
Jimmock. :wnkr
I hate people I don't like !
Re: VM 28 or VM 29s
#12 PostAuthor: zed1015 » Tue Aug 19, 2014 6:15 pm
snotie1965 wrote:
zed1015 wrote:
Thanks :D
Gs1000 used either 26mm or 28mm slides depending on model before going to CV's.
The 998cc homologation Katana used 32mm smoothbores (the 1100 used CV's)
markz9
smootbores
#13 PostAuthor: markz9 » Wed Aug 20, 2014 11:21 am
i recently got some gs1000 parts and was told 1 set of carbs where off a katana 998cc does the inside of the carb body change into an oval shape rather than staying round all the way through??
mark
Crofty
#14 PostAuthor: Crofty » Wed Aug 20, 2014 6:19 pm
There were some Katana carbs that had oval throats.
Re: smootbores
#15 PostAuthor: zed1015 » Wed Aug 20, 2014 8:20 pm
markz9 wrote:i recently got some gs1000 parts and was told 1 set of carbs where off a katana 998cc does the inside of the carb body change into an oval shape rather than staying round all the way through??
mark
Yes! They are oval at the venturi.
