Dyna S
wilsonsjw11
Dyna S
#1 PostAuthor: wilsonsjw11 » Sat Aug 23, 2014 5:53 pm
Just fitted Dyna S to my 73 Z1 and cannot get it to fire,on the F mark on both 1+4 and 2+3 I have slotted the back plate to the point if I go any further it would block the points cover fixing screws.The magnet is correct for an early advancer marked 3A and a NOS early advancer is fitted.The modules are right at the end of their adjustment limits.The closest I can get it is to fire on the T mark.
Regards
Steve
#2 PostAuthor: Pigford » Sat Aug 23, 2014 5:59 pm
You've probably got the wrong rotor (magnet trigger centre) :??
You can file the holes to get it correct, no big deal :wink:
#3 PostAuthor: z1bman » Sat Aug 23, 2014 6:00 pm
have you checked the locating peg in the crank which secures the advancer in the correct position?
#4 PostAuthor: PAULJAC47 » Sat Aug 23, 2014 6:08 pm
Try fitting the modules to the rear of the plate sometimes you can get away with that trick,there is a small amount of adjustment on the modules ...
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Sat Aug 23, 2014 6:08 pm
Locating pin on crank correctly located into advancer.
3A advancer fitted which I believe is correct for a 73 Z1 can anyone confirm this.
Regards
Steve
#6 PostAuthor: z1bman » Sat Aug 23, 2014 6:16 pm
yes 3a is for the early advancer are you sure the advancer is the correct one? are the heel's of the bob weights worn?
#7 PostAuthor: ZedHead » Sat Aug 23, 2014 6:21 pm
Is the rotor the right way on the advancer? Their is a small magnet on one side that most face left when the 1- 4 side of the advancer is pointing up. Also make sure the rotor is properly engaged.
Static timing should be done with the rotor held fully clockwise(advanced) so that the timing light comes on when the right hand 1-4 mark is in line with the crankcase mark.
Hope this makes sense.
#8 PostAuthor: z1bman » Sat Aug 23, 2014 6:27 pm
this is the early advancer the later one has 005 stamped on the base
#9 PostAuthor: ZedHead » Sat Aug 23, 2014 6:32 pm
z1bman wrote:this is the early advancer the later one has 005 stamped on the base
Does it make a difference? Is the timing different in some way. Worn bob weights is plausible.
#10 PostAuthor: z1bman » Sat Aug 23, 2014 6:36 pm
10 or more degrees difference between the early model & the later advancer
later type advancer
#11 PostAuthor: ZedHead » Sat Aug 23, 2014 6:41 pm
z1bman wrote:10 degrees difference between the early model & the later advancer
later type advancer
Thanks ... that is a lot
wilsonsjw11
#12 PostAuthor: wilsonsjw11 » Sat Aug 23, 2014 8:03 pm
As my earlier text said a NOS early advancer is fitted.
Thanks to PaulJac, I reversed the mounting plate and all is ok now.
It even runs and advances as it should.
Regards
Steve
wilsonsjw11
#13 PostAuthor: wilsonsjw11 » Sun Aug 24, 2014 8:48 am
Could someone please tell me where the advance marks are on a early advancer which are meant to be about 1/2 inch to the right of the 'F' mark for 1+4 and 2+3 or do you use the pivot pin as the mark.
Regards
Steve
#14 PostAuthor: z1bman » Sun Aug 24, 2014 9:07 am
there is a tiny mark close the the bob weight pivot
wilsonsjw11
#15 PostAuthor: wilsonsjw11 » Sun Aug 24, 2014 9:12 am
Z1b man I've got the magnifying glass on it but cannot see it :shock:
Is it just before the bob weight pivot arm.
I have 2 early advancers and cannot see it on either.
Regards
Steve
