Cam cover gasket
jacobmarley
Cam cover gasket
#1 PostAuthor: jacobmarley » Mon Dec 03, 2007 6:56 pm
Gents some advice please, I am going to check my valve clearances shortly and have a weep of oil from the cover gasket. Do I need a new gasket or could I use some liquid gasket( Hermatite?) to replace current gasket. What is your advice and experiences. - Jacobmarley (KZ1000 1979)
uk kev
#2 PostAuthor: uk kev » Mon Dec 03, 2007 7:07 pm
Fit a new gasket, they are only cheap in the big scheme of things, and look so much better than gasket seal.
Steve S
#3 PostAuthor: Steve S » Mon Dec 03, 2007 7:15 pm
At the end of the day it is up to you, but I personaly would fit a new gasket, especially as the old one is already leaking, :cry: if it was a fairly new gasket and has only been on there a short time I might re-use it as they do sometimes need re-torqueing after bedding in. :D ..but go on treat it its Christmas
#4 PostAuthor: Pigford » Mon Dec 03, 2007 8:15 pm
I wouldn't just use a sealant, as the gaskets are quite thick, for a reason :|
If they were just paper gaskets, maybe, but cam gaskets being a couple of 'mm' thick, this must be to allow for a bit of movement and/or irregularity between surfaces. Don't want those cams rubbing the cover :wink:
I'd reuse the gasket if it seems quite intact and not hard or over-compressed, with a smear of sealant to be sure :P
Davy Doherty
#5 PostAuthor: Davy Doherty » Mon Dec 03, 2007 8:19 pm
TO BE SURE!!! sir,
jacobmarley
Cam Cover Gasket
#6 PostAuthor: jacobmarley » Tue Dec 04, 2007 7:15 pm
Thanks for the advice gents - new gasket it is. - Jacobmarley
