Fitting Tarozzi rearsets on a Z1000
becker
#16 PostAuthor: becker » Wed Sep 24, 2014 4:36 pm
Mark Tiller wrote:Your last photo shows you trying to put the gear link rod into the brake side......I have instructions for assembly if you don't? have you mixed the bits up?
pretty sure thats the brake side bits - had all been assembled by seller - but suppose they could have done it wrong, but doubt it, just need to look at his projects, quite good with spanners.
if you're able scan and send me instructions at least I could check.
cheers
When life hands you lemons, reach for the vodka.
Z1B (in Z1A colours), Z1000A1, ZRX1100 C4, Suzuki TS125J (being restored), Suzuki T125J (in boxes), Garelli Rekord MKII (awaiting restoration), most of a Garelli Rekord MKI
KeithZ1R
#17 PostAuthor: KeithZ1R » Wed Sep 24, 2014 4:38 pm
Daryl
looking at your pictures you could be confusing yourself cos they are assembled wrong this is what you should have
you may have to "tweek" the push rod arm clevis to Master Cylinder to get it to run smooth, notice there are washers to fit into the casting recess holes for the mounting nuts to sit on also the brake cantilever arrangement may need some adjustment to get it to run smoothly sorry if this all sounds condescending but the exploded diagram may help if you aint got it
good luck
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Mark Tiller
#18 PostAuthor: Mark Tiller » Wed Sep 24, 2014 5:04 pm
cheers
02-0077 is the brake rod....has a domed top, I used my existing one as it wasn't in the kit I got
07962421462
becker
#19 PostAuthor: becker » Wed Sep 24, 2014 5:07 pm
Cheers Keith,
look at that drawing I'm missing some bits :shock: which would explain why it doesn't look like it will fit and why it looks like the gear side :roll:
looks like the main part I'm missing is 01 0012 and all the bits that bolt to it - back to the seller, see if he has them :(
freddyz1r
#20 PostAuthor: freddyz1r » Wed Sep 24, 2014 5:22 pm
becker wrote:Cheers Keith,
tarozzis are model specific :?:
01-0012 is for a z1000/z1r :?:
you said this kit was bought for a z900 :?:
there are 2 z900 kits :?: neither have 01-0012.
Freddy
freddyz1r
PUM 329
becker
#21 PostAuthor: becker » Wed Sep 24, 2014 5:27 pm
Freddy
ah-ha, cheers freedy - looks like the mistery is solved :)
anyone want to buy a set of z900 Tarozzi rearsets :lol:
freddyz1r
#22 PostAuthor: freddyz1r » Wed Sep 24, 2014 5:31 pm
No problem 'FREEDY' :lol:
I've been called worse :lol:
freddyz1r
PUM 329
Dodgy Z1B
#23 PostAuthor: Dodgy Z1B » Thu Sep 25, 2014 6:13 am
Sorry to hi jack this thread but could someone post pictures of z1b brake side fitted as I may have the opposite problem z1000 bits instead of z900.
becker
#24 PostAuthor: becker » Thu Sep 25, 2014 7:20 am
Dodgy Z1B wrote:Sorry to hi jack this thread but could someone post pictures of z1b brake side fitted as I may have the opposite problem z1000 bits instead of z900.
Sounds like we might both benefit from doing a swap of kits? :wink:
#25 PostAuthor: ADRIAN H » Thu Sep 25, 2014 11:30 am
Z900 Rear Disc
Z900 Drum (1976 onwards, none listed for earlier bikes
Neilnorth
Tarozzi Rearsets
#26 PostAuthor: Neilnorth » Tue Oct 07, 2014 12:40 pm
Hi Becker, seen your post re your rear sets ,
Did you get them sorted ?
If you still have the Z900 rear sets would you want to sell them ?
Regards Neilnorth :)
becker
Re: Tarozzi Rearsets
#27 PostAuthor: becker » Tue Oct 07, 2014 1:41 pm
Neilnorth wrote:Hi Becker, seen your post re your rear sets ,
Hi Neil,
Haven't done anything with them since this - got distracted with 1 of my daugthers cars problem. :roll:
Yep, reckon the best thing would be to sell them on and buy a Z1000 kit, rather than trying to get the separate parts to make this a Z1000 kit.
They are not in box, but are un-used - bought from a club member for his project, but he changed his plans and as you know I haven't been able to fit them to use them.
Can’t remember what I paid for them – they are around £230 new – fancy making me an offer via PM?
