dyna coils
royboy
dyna coils
#1 PostAuthor: royboy » Tue Oct 07, 2014 8:32 pm
hi all
just wondering if anyone has had a bad dyna coil from new,just fitted
new dyna electronic ignition and coils,but only getting spark on 2/3 not on 1/4,changed wires round to check modules on electronic ignition all ok.
changed coils over now sparking 1/4 and not 2/3,have put insulating tape round spacer near wire inputs,getting power to coils no spark,so would you say bad coil.
royboy
Mark Tiller
#2 PostAuthor: Mark Tiller » Tue Oct 07, 2014 9:05 pm
test across coil terminals with a meter ....do you get the same measurement in ohms?
07962421462
Garn 1
#3 PostAuthor: Garn 1 » Wed Oct 08, 2014 3:11 am
Yes, as MarkT says..
The primary windings should read 3 to 4 ohms across them, whereas, the secondary windings should read 13 to 14 kohms assuming they are the "green " variety.
Also, check that the secondary coil caps have good connectivity.
I found by pointing the coil spouts towards the top front, I had to use longer plug leads. I purchased some right angle adaptors to save some length of lead.
It does sound as so you have a defective coil, which Dyna will/ should replace.
royboy
coils
#4 PostAuthor: royboy » Wed Oct 08, 2014 7:27 pm
thanks all
phoned supplier, he said send back and will replace. so all ok.
Users browsing this forum: No registered users and 196 guests
