Ok Question time...... - this is the first of what will probably be many!
- london calling
Quote: from Rich on 7:01 pm on Aug. 31, 2006
Oil pressure switch - ZX1100 A2 it may be on the sump pan underneath the gearbox sprocket. Have a look on http://www.buykawasaki.com/ under "owner info" at the parts book for 1984, the breather cover/oil pan section shows it there.
That's another pint you owe me!
Kev - if you had bothered to go where I told you 2 days ago you would have found it, you may also have realised that you don't have an oil pressure switch, you have a level sensor and that you don't need a pressure switch. The oil will flow better without the obstruction caused by the pressure switch in the oil gallery.
I did and I don't have your acumen for sourcing parts.
If you are genuinly looking for knowledge then I apologise, but as I said this thread doesn't sound quite right to me!
- london calling
EARL'S performance products do an oil cooler take off for the Z1000J models part number ED31.This has proper threaded union connections not push on ones as per the ebay item.
sales@earls.co.uk
www.earls.co.uk
sales@earls.co.uk
www.earls.co.uk
Users browsing this forum: No registered users and 89 guests
