Boyer problems
z650freak
Boyer problems
#1 PostAuthor: z650freak » Sun Oct 26, 2014 9:14 pm
Has anyone had problems with a boyers electronic ignition black box going kaput??? Are they possible to test?? Thanks
GPRD
#2 PostAuthor: GPRD » Sun Oct 26, 2014 9:39 pm
Depending on how old it is they'll test it for free, and fix it if its broke, but if it isn't broke they'll charge you 15 plus postage (I seem to remember).
What we got here, is failure to comunicate.
z650freak
#3 PostAuthor: z650freak » Sun Oct 26, 2014 9:42 pm
GPRD wrote:Depending on how old it is they'll test it for free, and fix it if its broke, but if it isn't broke they'll charge you 15 plus postage (I seem to remember).
Thanks will contact them tomorrow
KWACKERZ1
#4 PostAuthor: KWACKERZ1 » Tue Oct 28, 2014 6:12 pm
HI I might have one to sell if you need to replace it, I have a few so let me have the model number as I am unsure if mine are 650 or 100.
You could always try it first to prove yours.
Phil
z650freak
#5 PostAuthor: z650freak » Tue Oct 28, 2014 7:56 pm
KWACKERZ1 wrote:HI I might have one to sell if you need to replace it, I have a few so let me have the model number as I am unsure if mine are 650 or 100.
Phil
Thanks for the offer but the wiring loom on a bitsa I just bought has a Boyer black box attached still....happy days :lol:
#6 PostAuthor: ZedHead » Tue Oct 28, 2014 9:40 pm
Testing the boyer box is easy. Touching the black and green pickup wires together should generate a spark. PM me if its goosed and I'lll sell you a Dyna S :D
Big Fluff
#7 PostAuthor: Big Fluff » Wed Oct 29, 2014 2:54 pm
Yes, fit a Dyna-S ignition system, loads better.
I've wired bikes for over 25 years and have seen plenty of Boyer black boxes f#ck up. The thin tracks can easily burn out. I used to solder new tracks in, very difficult but possible to fix.
Personally I would jumk it and go Dyna!
Will
z650freak
#8 PostAuthor: z650freak » Sun Nov 16, 2014 6:51 pm
Well we got the Boyer box changed over with one off a knackered and bodged loom and she's alive again....but only running on three again ffs :(
Taffus
#9 PostAuthor: Taffus » Sun Nov 16, 2014 7:52 pm
Hi Paul
I must admit I'm not a fan of the boyer, far to complimented for what its trying to achieve, you only have to look at the relative simplicity of the dyna s.
I personally prefer the newtronics system but even that is overkill when the dyna S does it so well..........
z650freak
#10 PostAuthor: z650freak » Sun Nov 16, 2014 8:24 pm
Taffus wrote:Hi Paul
I hear what you are saying but not my bike and we are working to a budget of......not a lot. At least it's running and we are back to where we started just need to track down this problem of running on three......
Taffus
#11 PostAuthor: Taffus » Sun Nov 16, 2014 8:28 pm
lead or plug then
I once found 1 output of a dyna coil corroded where you plug in. Cleaned it up and problem solved
