Marzocchi strada
Marzocchi strada
#1 PostAuthor: ADRIAN H » Mon Nov 03, 2014 9:07 pm
Does anyone know the colour code, for the red paint on the Marzocchi shocks, and where I can buy it from ?
thanks in advance.
Charlie
#2 PostAuthor: Charlie » Tue Nov 04, 2014 5:59 pm
If you are painting, try Fiat Swift Red - that's what I used on one set. The other set I had powder coated :)
z650freak
#3 PostAuthor: z650freak » Tue Nov 04, 2014 8:08 pm
Where did you get replacement seals etc Charlie? Ebay? Thanks
Anybody on here refurbish for members?
Crofty
#4 PostAuthor: Crofty » Tue Nov 04, 2014 8:44 pm
http://marzocchimoto.blogspot.co.uk/p/a ... t-now.html
Be aware the air reservoir caps can be corroded into the housing, if you want to borrow a special tap to chase the threads in the housing, let me know I have one you can borrow.
Charlie and I have both had to destroy the screw in tops to service and then salvage a cap from another set of worn out housings.
You do find some that come out easy as well.
http://www.ducatimeccanica.com/marzocchi1.html
z650freak
#5 PostAuthor: z650freak » Tue Nov 04, 2014 9:20 pm
Crofty wrote:http://marzocchimoto.blogspot.co.uk/p/ag-strada-kit-buy-it-now.html
Excellent. Thanks for the links and comments.
Charlie
#6 PostAuthor: Charlie » Wed Nov 05, 2014 7:05 pm
I still have a few bits from the many shocks I bought to strip and cannibalise. I dunno if I have any reservoir caps left, but if you get stuck for anything, give me a shout and I'll check if I have anything in the shed :)
Seal kits were on a 4 week waiting list from Marzocchi last time I looked, strip yours first to be sure you CAN actually get them apart without damage before committing to a seal kit that could turn out to be no good to you ;)
Use a good quality suspension oil when you rebuild. I used Motorex in mine but if you cannot get that, use Motul - they are the best shock oil manufacturers bar none. Silkolene,Putoline,Rock etc - all go to a milky piss in next to no time.
Users browsing this forum: No registered users and 111 guests
