Z thou Rotor holding tool
#1 PostAuthor: PAULJAC47 » Sat Nov 08, 2014 5:34 pm
Guyz does the club have a rotor holding tool for holding rotor steady to torque up the bolt? or does anyone have one i could borrow please? Ta PaulJ
Jay1969
#2 PostAuthor: Jay1969 » Sat Nov 08, 2014 5:43 pm
In case anyone wants to buy one for future - http://www.gbmotorcycleproducts.com/kaw ... -567-p.asp
#3 PostAuthor: chrisu » Sat Nov 08, 2014 6:01 pm
I've always done this with the engine fitted in the bike.
in gear, assistant with their foot on the back brake and torque it up.
#4 PostAuthor: PAULJAC47 » Sat Nov 08, 2014 6:04 pm
Tried that Chris clutch didnt hold it only diff is its a lock up clutch!
Padders
#5 PostAuthor: Padders » Sat Nov 08, 2014 6:14 pm
I use a heavy duty strap oil filter wrench Paul to hold the rotor enough to tighten the bolt. only around £9.00 posted on e bay
PUM 13
#6 PostAuthor: z1bman » Sat Nov 08, 2014 6:24 pm
Paul can you measure the outside diameter of the rotor as i did have a genuine one but lent it out & it has not returned :x :x
Crofty
#7 PostAuthor: Crofty » Sat Nov 08, 2014 6:56 pm
Easy enough to make if you have a welder, I made one that fits 650/750 engines.
#8 PostAuthor: chrisu » Sat Nov 08, 2014 7:58 pm
PAULJAC47 wrote:Tried that Chris clutch didnt hold it only diff is its a lock up clutch!
Ah yes... :oops:
scott
Junior Section leader
#9 PostAuthor: scott » Sat Nov 08, 2014 8:20 pm
Paul, I'm sure I've got one if you need to borrow
#10 PostAuthor: PAULJAC47 » Sat Nov 08, 2014 8:28 pm
Thanks Scott please check,happy to pay post,going to try filter,ratchet wraps tommorow....Ta Paul J
scott
#11 PostAuthor: scott » Sat Nov 08, 2014 8:49 pm
Oakey dokey, shout if you need it
#12 PostAuthor: PAULJAC47 » Sun Nov 09, 2014 4:04 pm
Sorted made one up from piece of flat steel,checked torque all ok,,,Thanks for advice Guyz
Users browsing this forum: No registered users and 153 guests
