Z800 Cafe Chopper Fighter thing...
j.wilson
#241 PostAuthor: j.wilson » Sun Oct 05, 2014 11:05 pm
What's happening with the project Roy?
z650/1400 bonneville hybrid.
Crofty
#242 PostAuthor: Crofty » Mon Oct 06, 2014 6:41 am
Hi Ratch, I have been wondering too, you must be close to firing the beast up?
Jim
Royalratch
#243 PostAuthor: Royalratch » Thu Oct 23, 2014 2:55 pm
Update soon guys. Missed this summer as launch date again because of work.
But things have been happening.
All finished except for loom which I've been flip-flopping on the approach.
Also been constantly adding last minute touches which is also slowing it down but I've made a decision to to just get it finished and finesse it later.
Royalratch
#244 PostAuthor: Royalratch » Mon Nov 10, 2014 7:21 am
Embarrassing question.
Fitting the rubber bushes for the side panel to press into - impossible to go in. Starting to think I've got the wrong size? Tried with grease and they are just a bitch.
Any tips?
:oops:
freddyz1r
#245 PostAuthor: freddyz1r » Mon Nov 10, 2014 7:43 am
Wrong size :oops:
a tight comfortable fit is what's required :up
zpower sell them
cheerz freddy :D
freddyz1r
PUM 329
Royalratch
#246 PostAuthor: Royalratch » Mon Nov 10, 2014 7:59 am
Cheers dude. There's more one than size…?
freddyz1r
#247 PostAuthor: freddyz1r » Mon Nov 10, 2014 9:27 am
freddyz1r
PUM 329
Crofty
#248 PostAuthor: Crofty » Mon Nov 10, 2014 9:31 am
Ratch, The replacement rubbers can be tight, only one size. I sanded the pegs down on the back a bit at a time and used Castrol red rubber grease to make the pins slide in easily. The lh side panel lower peg is notoriously weak, so make sure they are not too tight.
freddyz1r
#249 PostAuthor: freddyz1r » Mon Nov 10, 2014 9:31 am
I bought some of this site (vehicle wiring), came in a multi -pack, of different sizes.
http://www.vehicle-wiring-products.eu/s ... 54b3a65d9b
cheerz freddy :D
freddyz1r
PUM 329
freddyz1r
#250 PostAuthor: freddyz1r » Mon Nov 10, 2014 9:39 am
Royalratch wrote:Cheers dude. There's more one than size…?
Sorry, I thought there were 2:oops: for that panel. My opologies for giving you the wrong link. :bow
cheerz freddy :D
freddyz1r
PUM 329
jimmock
#251 PostAuthor: jimmock » Mon Nov 10, 2014 10:06 am
Fairy liquid is ideal for this kind of job!!
Jimmock. :wnkr
I hate people I don't like !
Royalratch
#252 PostAuthor: Royalratch » Mon Nov 10, 2014 2:28 pm
Crofty wrote:Hi Ratch, I have been wondering too, you must be close to firing the beast up?
Jim
Hey bud.
I'm talking about getting the bloody things into the frame! Tried with grease, pinching with pliers - impossible.
Maybe the powdercoating is not helping...?
Crofty
#253 PostAuthor: Crofty » Mon Nov 10, 2014 3:47 pm
Never had a prob getting them into the frame, even with powder coat on. Try putting them in hot water to soften em up a .
Royalratch
#254 PostAuthor: Royalratch » Wed Nov 19, 2014 3:12 pm
Quick update just to show the build is alive albeit a lot more lackadaisical.
Battery box is finished. Needed a custom one to mount all the willy wonka electronics bits. Threaded rods will be trimmed down after loom is sorted at the right length and box will go back for powdercoating.
Motodadget + Keyless Ignition Reciever
Reg/Rec
Rear view - Main Fuse
Starter Relay, Earth Bar and 12v-5v to power the Bluetooth Relay (for remote iPhone starting).
Also decided the calipers needed refresh which turned into a mini-project. Was originally just going to sort the pistons out and new washers ended up machining the logo off, complete refurb and built back up with all Stainless hardware. Looks more custom now and less parts bin.
Also on the hardware theme had to sort some of the main nuts and bolts across the bike.
The swing arm pivot bolt I had been using was too short. It was manky anyway so had one made in Stainless, finished off with the Titanium nut.
More Ti fasteners and nuts. If you want gold AND strength its gotta be Ti.
Headlamp built up and fitted.
Also decided to go with some brand new Ohlins as the used ones, though very tidy were letting the side down lol.
As it stands now…
Just got to attack the loom now, which I have all the parts for, some nice braided HT leads etc - over the Xmas break.
jimmock
#255 PostAuthor: jimmock » Wed Nov 19, 2014 4:38 pm
Reference the last pic.
Is that a big house you are working in??
It looks like a great place to be.
Jimmock. :wnkr
