Aeroquip front sprocket nut torqe
#1 PostAuthor: PAULJAC47 » Sat Nov 15, 2014 4:57 pm
Guyz just fitted new 530 chain conversion to Z thou,supplied with Aeroquip front nut,have read Debbens torque these to 75 ft Lb,s as there is no locktab what are other opinions on this?...PaulJ
#2 PostAuthor: Ginger Bear » Sat Nov 15, 2014 5:27 pm
Paul,
Debbens have been doing this long enough..... I'd take their advice.
# 104
#3 PostAuthor: PAULJAC47 » Sat Nov 15, 2014 6:56 pm
First time i have used one of these nuts Steve, i take it its a fit once item due to theb triangular pressings on the outer?
#4 PostAuthor: Ginger Bear » Sun Nov 16, 2014 8:57 am
Never seen one either Paul (any pics?). But like I've already said, Ray & Steve know their stuff.
# 104
CAT3
#5 PostAuthor: CAT3 » Sun Nov 16, 2014 11:01 am
Sounds like the sort of nuts used on aircraft. The triangular pressing on the top of the nut slightly deform the thread, making it tight when the nut is fully threaded onto it's mating bolt/stud.
Just follow the fitting instructions, but if it really bothers you, you could apply a little low strength Loctite, but really there shouldn't be any need for this.
ade woollams
#6 PostAuthor: ade woollams » Sun Nov 16, 2014 11:28 am
don't the sprocket nuts on the gpz 1100 use a similar method
snotie1965
#7 PostAuthor: snotie1965 » Sun Nov 16, 2014 1:55 pm
ade woollams wrote:don't the sprocket nuts on the gpz 1100 use a similar method
gpz1100 uni-traks use a washer that fits onto the splines of the output shaft, then torque the nut on, and bend the washer over the nut , 100% method ?
#8 PostAuthor: PAULJAC47 » Sun Nov 16, 2014 3:39 pm
Reckon these are used in Aircraft!,nipped it up to 75ft ibs seems much better to me than the tab washers, so do Debbens! dont fancy taking it off though :lol:
ade woollams
#9 PostAuthor: ade woollams » Sun Nov 16, 2014 3:49 pm
that's the same shape as the one they gave me at cradley which they said fitted the gpz shaft
Users browsing this forum: No registered users and 117 guests
