the start of the story
bought a 1975 Z1B non runner must of been stood for 25 years in the usa few engine parts missing alternator and cogs for electric start and bolt for timeing on the other side located these as i got it running with the kick start
stripped and cleaned the carbs electric start working but seemed a bit lumpy but hard to detect as no baffles in exhaust all four cylinders sparking and warm
SO did a compression test 25 75 100 110 psi ?????
filled the two lowest with redex for 2 hours but the 25psi would not fill so then ran the bike with redex in all 4 cylinders from a bottle smoked its head off
did another compression test results 45 130 130 130 sio still have a problem so its either hole in piston rings stuck or broke bent valve or could it be anything else
(Edited by steve f at 10:08 am on Sep. 3, 2006)
Engine problems help
- big green bus
steve f
