Relay-Wired George.
wilsonsjw11
Relay-Wired George.
#1 PostAuthor: wilsonsjw11 » Sat Nov 29, 2014 3:07 pm
Can someone point me in the right direction as to where to purchase a 10A relay c/w diode to carry out the wired George mod please.
Regards
Steve
#2 PostAuthor: Pigford » Sat Nov 29, 2014 3:37 pm
MAPLINS
baz
#3 PostAuthor: baz » Sat Nov 29, 2014 4:14 pm
whats the wired george mod ? :oops:
#4 PostAuthor: Pigford » Sat Nov 29, 2014 4:25 pm
baz wrote:whats the wired george mod ? :oops:
Where you been :lol:
Relay to supply 12v direct to ignition - so no losses thru kill switch, etc
Mark Tiller
#5 PostAuthor: Mark Tiller » Sat Nov 29, 2014 4:28 pm
07962421462
Mark Tiller
#6 PostAuthor: Mark Tiller » Sat Nov 29, 2014 4:29 pm
http://www.wgcarbs.com/index.php/using- ... s/89-coils
07962421462
Mowjoe
#7 PostAuthor: Mowjoe » Sat Nov 29, 2014 4:45 pm
Great mod this but I didn't use diodes just wired as per drawing no probs yet!
Z900-A4 looking like a Z1B!
wilsonsjw11
#8 PostAuthor: wilsonsjw11 » Sat Nov 29, 2014 5:06 pm
Mark Tiller,
Has the relay, that's available through ebay, got the diode fitted :?:
Regards
Steve
Mark Tiller
#9 PostAuthor: Mark Tiller » Sat Nov 29, 2014 5:40 pm
wilsonsjw11 wrote:Mark Tiller,
Regards
Steve
don't know, works fine on mine....why do you need a diode?
07962421462
z650freak
#10 PostAuthor: z650freak » Sat Nov 29, 2014 6:06 pm
Regards
Steve
Yes wondered that as well....
Have you got any photos of the mod and where you mounted the relay please :?:
Some of the other forum links appear to point to a five pin relay :?:
#11 PostAuthor: PAULJAC47 » Sat Nov 29, 2014 6:19 pm
Dont need a Diode for this mod..
#12 PostAuthor: Pigford » Sat Nov 29, 2014 6:38 pm
The diode protects the ignition from a voltage surge/change - or summink like that when turned on/off :|
Diodes are like 1-way valves I do believe :!:
Chris Riv
#13 PostAuthor: Chris Riv » Sat Nov 29, 2014 6:43 pm
I believe the diode is to protect electronic kit (eg dyna s) from voltage induced by the normal operation of the relay.
There's some info on the Hella website explaining in more detail.
Mark Tiller
#14 PostAuthor: Mark Tiller » Sat Nov 29, 2014 7:29 pm
stick a link on if you find one with a diode
07962421462
z650freak
#15 PostAuthor: z650freak » Sat Nov 29, 2014 7:44 pm
Chris Riv wrote:I believe the diode is to protect electronic kit (eg dyna s) from voltage induced by the normal operation of the relay.
Where's the diode in the circuit without the wired George mod ?
There's a normal surge anyway in the circuits anyway when switching on and off the ignition....very visible on Zeddy's z650 last week when using inline spark testers....so why have one on a relay added into the wiring?
