Carb choke tube
Gavin
Carb choke tube
#1 PostAuthor: Gavin » Sat Dec 13, 2014 11:34 am
Are you able to buy new ones, a set of z1000 carbs I have has a tube broken off, if they are available who do I need to contact.
Z1000 MK2
Z1300 DFI
#2 PostAuthor: z1bman » Sat Dec 13, 2014 12:06 pm
its not a separate part you will need to remove one from a scrap carb or buy some brass tube. if you have the broken bit remove the jet from the bottom of the tube by taping it out from the inside & press it into the new tube
http://www.ebay.co.uk/itm/Brass-Tube-Pi ... 20f0d2669c
wheelysteve
#3 PostAuthor: wheelysteve » Sat Dec 13, 2014 5:15 pm
Gavin, is it this bit you need?
If it is I've got a spare one, just pm me
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Gavin
#4 PostAuthor: Gavin » Sat Dec 13, 2014 6:27 pm
wheelysteve wrote:Gavin, is it this bit you need?
Steve
Pm sent
Z1000 MK2
Z1300 DFI
Gavin
#5 PostAuthor: Gavin » Sat Jan 03, 2015 7:18 am
Steve
Got home yesterday to find amongst the normal mail that gets put through the letterbox a battered envelope containing the choke tube,
It appears that it had been delivered to the wrong address and reposted.
Thanks a lot , it goes to show what a great groupwe have here
I hope you had a great Xmas and start to the New Year.
Z1000 MK2
Z1300 DFI
wheelysteve
#6 PostAuthor: wheelysteve » Sat Jan 03, 2015 10:05 am
Cheers Gavin, same to you. Glad you are sorted now. Steve
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
