Z1R Fuel Gauge sender
Kev1R
#1 PostAuthor: Kev1R » Fri Dec 12, 2014 10:11 pm
I suspect I have a dodgy fuel gauge sender (the bit that sits inside the tank) - Does anyone know if they are repairable / rebuildable?
It does not look as though it is intended to be taken apart, as it is secured together with metal tabs rather than screws.
Is there a more modern alternative unit that would do the job?
I tend to rely more on how many miles I've covered since the last fill up rather than the gauge so it is more of an annoyance than a major problem.
Be nice to get it working properly again though!
010
#2 PostAuthor: PAULJAC47 » Sat Dec 13, 2014 9:58 am
Hi Kev if you can take apart should be no more than a slider contact moving on a coiled resistance wire worth taking out, cleaning contacts and testing with an ohmeter or even better testing while out of the tank to the gauge..Paul J
KeithZ1R
#3 PostAuthor: KeithZ1R » Sat Dec 13, 2014 11:09 am
everything Paul has sed however its more likely to be the meter
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Kev1R
#4 PostAuthor: Kev1R » Sat Dec 13, 2014 2:33 pm
Thanks for response guys - I will try cleaning it up - I did run a multimeter on it & smoothly moving the arm produced a range of readings all over the place - which made me suspect the sender.
Course i might have a faulty multimeter!!.............Where does it end?
Kev
010
jimmock
#5 PostAuthor: jimmock » Sat Dec 13, 2014 2:42 pm
When you are checking out / repairing the fuel sender issues..........
Do something with the truly hideous FRONT BRAKE SET UP !!!!!
Jimmock. :wnkr
I hate people I don't like !
Keefleaf
#6 PostAuthor: Keefleaf » Sat Dec 13, 2014 3:22 pm
I've got a spare if you get stuck.
KeithZ1R
#7 PostAuthor: KeithZ1R » Sat Dec 13, 2014 3:25 pm
jimmock wrote:When you are checking out / repairing the fuel sender issues..........
Agreed .....make sure you put it back :D
Keith
:bop :gom
mistaken.
Kev1R
#8 PostAuthor: Kev1R » Sat Dec 13, 2014 5:16 pm
Cheers Keefleaf - I will bear that in mind
010
freddyz1r
#9 PostAuthor: freddyz1r » Sun Dec 14, 2014 2:33 pm
Hiya kev, I've got spares of senders and metres if you need to 'fault find'.
Cheerz freddy :D
freddyz1r
PUM 329
Kev1R
#10 PostAuthor: Kev1R » Sun Dec 14, 2014 4:24 pm
Thanks Freddy I'll have a look & see what transpires !
010
Users browsing this forum: celger7, Tinker, Ultim8pc and 49 guests
