Best size Carbs?
snotie1965
Haven't had it on the dyno yet motor is brand new Chris who built it reckons 125/130 bhp Bought it from Mike p off here in the summer its a 1000sz still have the original motor which had some head work done and was quick so looking forward to the spring to test the new motor
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
Ducati 1198R Race
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
nw66 wrote:Haven't had it on the dyno yet motor is brand new Chris who built it reckons 125/130 bhp Bought it from Mike p off here in the summer its a 1000sz still have the original motor which had some head work done and was quick so looking forward to the spring to test the new motor
Shit you have quite nice quiver of bikes there! The Kat looks awesome.
All these big bore bikes and large carbs are making me feel inadequate with my standard 900 and 29's...
Is Vic There
So are the carbs from a GSXR usually called flat slides?
I have a set of these that are bored out to 31mm, originally from a GSXR750 and then fitted and re-jetted to a Z1000.
Is Vic There wrote:So are the carbs from a GSXR usually called flat slides?
They got the name from the fact that the carbs have 'flat sides'...instead of the normal cylindrical shape.
Don't be fooled by the CV versions which often get palmed off as 'slabbies'.
Is Vic There
Hi Gary,
They are defiantly from a GSXR, have used J carb rubbers on the Z1000 head, just need decent clamps. Look good, not as good as CR but they'll do for the time being!
I ran a a set of Keihin CR35's on my old Moto-Martin, the motor ran 1135cc with a Phil Manzano head fitted with o/s valves and .425 Kent cams.
It was slightly over fueled but the acceleration was phenomenal.
- nick pearce
Which size CR's
I've found 33mm CRS worked very well for the last 20 years on my gpz1170 with kent cams , gas flowed head, bigger valves etc, but now tried 37mm CR's which give abit more top end and midrange hasn't really changed. Experimenting with my old 33mm CR's on my Z1000J at the moment- pug colour about right but flat spot just before it goes on cam. Could go back to CV's on J but don't want to lose any power. Good luck with it mate.
N Pearce
- nick pearce
- nick pearce
Re: Which size CR's
nick pearce wrote: now tried 37mm CR's which give abit more top end and midrange hasn't really changed.
What inlet rubbers do you use to fit CR37's to a GPz head?
