US Spec LTD Indicators
Farmer
#1 PostAuthor: Farmer » Sun Jan 18, 2015 10:11 am
When I turn the ignition on the front indicators come on, they still flash when you indicate but I`m wondering wether it will go through an MOT like this ?. :)
1981 KZ1000 K1 LTD
Redbeard
#2 PostAuthor: Redbeard » Sun Jan 18, 2015 10:46 am
Assuming they switch on and off then it shouldn't be an issue. US spec bikes often have lights switched on all the time, obviously not the indicators though.
1979 Z1000ST
#3 PostAuthor: z1bman » Sun Jan 18, 2015 10:54 am
the front indicators have a dual filament bulb fitted you can either change it for a standard single filament indicator bulb or remove the feed to indicator. standard European bikes would have two wires going to the lamp the american ones have three. identify the wire that feeds the lamp as a day light & disconnect it looking at the wiring diagram if you disconnect the blue wire to the indicator they should work normally
#4 PostAuthor: PAULJAC47 » Sun Jan 18, 2015 11:07 am
Import bike used as running lights in Us/Canada.
jimmock
#5 PostAuthor: jimmock » Sun Jan 18, 2015 11:23 am
Yes, I agree.
Running lights that double up as indicators.
Jimmock. :wnkr
I hate people I don't like !
Farmer
#6 PostAuthor: Farmer » Sun Jan 18, 2015 12:20 pm
z1bman wrote:the front indicators have a dual filament bulb fitted you can either change it for a standard single filament indicator bulb or remove the feed to indicator. standard European bikes would have two wires going to the lamp the american ones have three. identify the wire that feeds the lamp as a day light & disconnect it looking at the wiring diagram if you disconnect the blue wire to the indicator they should work normally
Thanks, quite an easy fix then. :)
1981 KZ1000 K1 LTD
Farmer
#7 PostAuthor: Farmer » Sun Jan 18, 2015 12:24 pm
[quote="Redbeard"]Assuming they switch on and off then it shouldn't be an issue. US spec bikes often have lights switched on all the time, obviously not the indicators though.[/quote
Yes the headlights are on all the time, no switch off. :)
1981 KZ1000 K1 LTD
fusionpaul
#8 PostAuthor: fusionpaul » Sun Jan 18, 2015 3:24 pm
Have a similar issue with a bike I've just imported from the US & as previous people have said you will be able to disconnect the running light wires in the headlight bucket, it won't pass its MOT like it is.
#9 PostAuthor: Pigford » Sun Jan 18, 2015 4:09 pm
Those Yanky light settings are always a blinking nuisance!
.......... got me coat already :oops:
ted1r
post
#10 PostAuthor: ted1r » Sun Jan 18, 2015 6:26 pm
There is no issue with the UK MOT and US yellow marker lights in the front. it will pass as my Z1000 police has .the one that will let you down is no side light in the US headlight.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
Yellow
#11 PostAuthor: Yellow » Sun Jan 18, 2015 7:40 pm
Had these on 650LTD, not a problem here as no MOT. Disconnected the sky blue wire in headlamp shell to each indicator and all was normal again...
Farmer
Re: post
#12 PostAuthor: Farmer » Sun Jan 18, 2015 9:33 pm
[quote="ted1r"]There is no issue with the UK MOT and US yellow marker lights in the front. it will pass as my Z1000 police has .the one that will let you down is no side light in the US headlight.
Ted[/quo
As soon as you turn the ignition on the headlight comes on, so a side is not needed is it ?, surely you would not be able to see it.
what about Harleys and their yellow marker lights ?. :)
1981 KZ1000 K1 LTD
#13 PostAuthor: z1bman » Sun Jan 18, 2015 10:16 pm
if the side light is fitted to the headlight & it has a switch to operate that light it must work for mot purposes. if there is no side light fitted & no switch it will pass the mot. as already stated the us headlight is on permanently so there is no point having a side light
Farmer
#14 PostAuthor: Farmer » Sun Jan 18, 2015 10:33 pm
z1bman wrote:if the side light is fitted to the headlight & it has a switch to operate that light it must work for mot purposes. if there is no side light fitted & no switch it will pass the mot. as already stated the us headlight is on permanently so there is no point having a side light
What about headlight glass, that will be for driving on the right won`t it ?. :)
1981 KZ1000 K1 LTD
#15 PostAuthor: z1bman » Sun Jan 18, 2015 11:46 pm
yes you will need to replace the headlight for a uk spec
Users browsing this forum: wheelysteve and 60 guests
