ELR headlight bracket and seat lock
Is Vic There
#1 PostAuthor: Is Vic There » Sun Jan 25, 2015 8:33 pm
If anyone has them please let me know :D
Of if anyone has an idea where they can be obtained?
Thanks in advance :D
Tonka
#2 PostAuthor: Tonka » Sun Jan 25, 2015 9:05 pm
Headlight bracket - One on ebay
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
#3 PostAuthor: paul doran » Sun Jan 25, 2015 9:35 pm
I have a seat lock but no key
Is Vic There
#4 PostAuthor: Is Vic There » Sun Jan 25, 2015 10:51 pm
Tonka wrote:Headlight bracket - One on ebay
Where? I'm not that good at fin ding stuff!
Is Vic There
#5 PostAuthor: Is Vic There » Sun Jan 25, 2015 10:51 pm
paul doran wrote:I have a seat lock but no key
Is it easy to get a key Paul?
Tonka
#6 PostAuthor: Tonka » Mon Jan 26, 2015 6:48 am
http://www.ebay.co.uk/itm/kawasaki-z100 ... 418f09f21a
Is Vic There
#7 PostAuthor: Is Vic There » Mon Jan 26, 2015 7:19 am
Thank you Tonka but I need the bracket that hold the actual light on.
#8 PostAuthor: paul doran » Mon Jan 26, 2015 5:39 pm
yes any good locksmith can cut one
Is Vic There
#9 PostAuthor: Is Vic There » Mon Jan 26, 2015 8:12 pm
paul doran wrote:yes any good locksmith can cut one
Would you like to part with it?
#10 PostAuthor: paul doran » Mon Jan 26, 2015 10:20 pm
I would but they are not easy to get hold of as I am sure You are aware
Is Vic There
#11 PostAuthor: Is Vic There » Tue Jan 27, 2015 12:17 am
paul doran wrote:I would but they are not easy to get hold of as I am sure You are aware
Well what was the point in posting that you had one :lol:
Is Vic There
#12 PostAuthor: Is Vic There » Tue Feb 10, 2015 10:19 am
Is this the right headlight bracket for the Z1000R?
http://www.ebay.co.uk/itm/NOS-Kawasaki- ... 2c6cede2fb
#13 PostAuthor: z1bman » Tue Feb 10, 2015 11:27 am
Is Vic There wrote:Is this the right headlight bracket for the Z1000R?
yes that is a correct bracket for the z1000r & the z1100r
martinz1000r
#14 PostAuthor: martinz1000r » Tue Feb 10, 2015 11:45 am
If it helps I have both GPz headlight mounts and the connecting piece that goes between both fork legs (the missing 22mm). I too went through a long search to find the right parts and bought these as a fix. I then found the right ones from an eBay seller in Denmark so they are surplus. I think I even got them plastic coated in satin black ready to use.
malmojoe
#15 PostAuthor: malmojoe » Tue Feb 10, 2015 11:49 am
It's different. The R2 is longer by 22mm at the bottom. I've bought 2 GPz1100 brackets for one of my R2s and I'm going to take them to a sheet metalworker to extend.
Last pair if R2 brackets I saw were £300 and no longer for sale. Been looking for ages so decided to check the GPz ones in the end. Exactly the same other than that.
Just saw Martins post and that seems like a good option IMO.
