Parts wanted for A4
sprint
Parts wanted for A4
#1 PostAuthor: sprint » Wed Jan 28, 2015 3:09 pm
I am seeking a couple of parts for a Z900A4.
1. A complete 5/8" front brake master cylinder for twin discs. The type I am looking for has the solid aluminium body and the flat top cap with the stick on decal.
2. Pair of seat hinges. These are the type that have the handed (mirror image) brks spot welded to one side and are used with the 'L' shaped hinge pins, as shown in the link.
https://www.google.co.uk/search?q=kawas ... 1976-model).aspx%253Fp%253D%3B640%3B480
#2 PostAuthor: PAULJAC47 » Wed Jan 28, 2015 3:17 pm
EFFAA410000P
EFFAA-410-000P
Go to David Silvers website and search for above part numbers,direct link dont work,its a master cylinder for a cb750 f2 same as a a4,
Used these before look the same and work well ,good price too...
#3 PostAuthor: z1bman » Wed Jan 28, 2015 4:07 pm
#4 PostAuthor: PAULJAC47 » Wed Jan 28, 2015 5:15 pm
Z1b man you have the link for the single caliper jobby,part numbers i have listed is for the Twin caliper for some reason the direct link to it wont work on Silvers Site!...Paul J
#5 PostAuthor: z1bman » Wed Jan 28, 2015 5:20 pm
#6 PostAuthor: PAULJAC47 » Wed Jan 28, 2015 5:24 pm
Thats it....You know that was £29 when i looked earlier today still cheap at £35
freddyz1r
#7 PostAuthor: freddyz1r » Wed Jan 28, 2015 5:33 pm
Definitely the right price :up good find
cheerz freddy :D
freddyz1r
PUM 329
sprint
#8 PostAuthor: sprint » Wed Jan 28, 2015 5:45 pm
Thanks for reply and link.
It is my understanding that the earlier Z1's used the master cylinder with the dome cap with the cast lettering but the A4 used the type which had the flat cap with the stuck on decal as in the link? It is also my understanding the caps are not interchangeable?
http://www.ebay.co.uk/itm/131269488671? ... EBIDX%3AIT
sprint
#9 PostAuthor: sprint » Wed Jan 28, 2015 5:49 pm
z1bman wrote:https://www.z-power.co.uk/merchantmanager/product_info.php?products_id=697
Thanks for the reply and link.
I had seen these on the Z-Power site but they have the side brk on the same side instead of being handed? Not really a major problem but would like to get the handed ones that were fitted originally if I can as in the link:
https://www.google.co.uk/search?q=kawas ... i-z900-a4-
#10 PostAuthor: z1bman » Wed Jan 28, 2015 6:34 pm
easy enough to modify i would grind of the spot weld & weld it on the opposite side
http://www.z-fever.de/ShopNeu/shop/show ... ri2kkal9a1
sprint
#11 PostAuthor: sprint » Thu Jan 29, 2015 8:23 am
This the DS link for the £29 version which they list as being 14mm so only suitable foe single disc?
https://www.davidsilverspares.co.uk/CB7 ... rt_123912/
My understanding was they they only do this MC in the in the one size, 5/8" so is DS just simply charging more for the same part because it is sold for a twin disc?
#12 PostAuthor: z1bman » Thu Jan 29, 2015 8:39 am
sprint wrote:This the DS link for the £29 version which they list as being 14mm so only suitable foe single disc?
it says in the description for dohc & twin cylinder m/c & not twin disc?
#13 PostAuthor: PAULJAC47 » Thu Jan 29, 2015 8:48 am
5/8=0.6250=15.88 MM.........So the 14mm one is too small for the twin set up.
#14 PostAuthor: z1bman » Thu Jan 29, 2015 9:30 am
the m/c in my post is for the twin disc/calliper
sprint
#15 PostAuthor: sprint » Thu Jan 29, 2015 12:51 pm
Spoke to DS.
There are two different MC's they do, one for single disc set up and one for twin disc. However, it is not possible to get any kits for the repro ones, you have to throw it away if there are any problems and buy a new one.
Also, the original type flat caps do not fit the repro ones.
