Q's Z900 A4
Pigford wrote:Getting to the really exciting stages now
I was hoping that Piggy, but have run into a stumbling block with the rear caliper
andyb1962 wrote:Excellent job Richard ! Be up and running in time for summer Wink
Certainly hope so Andy, I'll pop it round if you like.
Richard
1976 KZ900
1976 KZ900
Richard Q wrote:
I was hoping that Piggy, but have run into a stumbling block with the rear caliperIt needs a full rebuild but I am not 100% sure what it comes from. And the disc doesn't quite match the caliper, or it may be the pads which are wrong
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Pics
1976 KZ900 A4 fitted with a rear disc brake. Fairly sure it's from a '77/78 Z1000. Can anyone identify it?
I seem to be missing the pad springs and the anti-squeal shims.
The pad sits around 6mm too high. They overhang the disc and will obviously cause problems as the pad wears. The disc is (as close as I can measure) 277mm x 6mm. The pads are pictured with a ruler, and are 53mm high, with the centre of the holes at around 47.5mm.
Any ideas as to why the pads are in the wrong place? disc too small for a Z1000? If so, what size do I need? Wrong pads? Mismatched caliper/disc?
1976 KZ900
1976 KZ900
- ZedHead
Z1parR wrote:The disc on your wheel is very likely a Z650 disc .
+ 1 Disc is the problem.
- ZedHead
Steve Cooke wrote:Do you have the means to refurbish a disc? the one I have here has surface pitting on it so would need a slight skim but it is the full 8mm thickness so plenty to play with. It's undrilled, if you're interested you can have it for a lot less than that eBay one.
Hello Steve
Thanks for the offer, but I am contemplating buying a load of new stuff. As the state of it is quite appalling I might as well do the job once and for all.
Richard
1976 KZ900
1976 KZ900
