Lockheed
I think the modern equivalent of Lockhead calipers are AP racing calipers ref CP2696. Andover Norton cheapest stockist in UK.
I have a pair of AP Lockheed calipers. CR2696 twin piston. Came with my Harris in a big box of bits. Can't guarantee seals etc but pistons do seem to move. You will need pads/pins. They are AP Lockheed branded so are old (current ones only have AP in the casting).
£100 the pair posted if interested. There is also a matching master cylinder but it has no break lever. Again old as full metal casting including fluid reservoir and cap. New ones are plastic. Can add this for extra £50. Levers, pads etc available from Dennis Trollope Racing in Bristol.
Folks, someone else was even quicker off the mark with a PM! Rick obviously gets first shout but here are the offending items. What you see is what you get. Not tried, tested or fitted. I suspect OEM on a Norton or Triumph? Please advise:
Aaaargh B******. I should have put a wanted post up.
