front brake caliper ...?
bunnysZ
Granny Magnet
#1 PostAuthor: bunnysZ » Mon Dec 31, 2007 10:11 am
I am going to upgrade my bike from single to double caliper
the calipers i have differ slightly, in that the piston on one pair is solid , the other pair are empty, (as photo), the question is why the difference which is better/why and what models are they from.
#2 PostAuthor: Pigford » Mon Dec 31, 2007 10:15 am
BunnyZ, could be a replacement aftermarket part, or someones just fitted it in arse-about-face :?:
DogsbolloxofZ1B
#3 PostAuthor: DogsbolloxofZ1B » Tue Jan 01, 2008 5:23 pm
I agree, the one on the LHS is correct orientation.
dr.rod
#4 PostAuthor: dr.rod » Wed Jan 02, 2008 9:16 pm
The right hand piston has a ceramic insert to prevent heat transfer from the brake pad to the brake fluid in the caliper. It was a development on later models to prevent brake fade.
In real life it makes not a jot of difference.
scott
Junior Section leader
#5 PostAuthor: scott » Wed Jan 09, 2008 4:03 pm
Hi bunnyz,
i agree with dr.rod....i went through the same process as you did when converting kz1000a2 to a twin disc setup. Also make sure the disc thickness is the same as the one you already have....the american one is thicker than the euro one.
Scott
