Which is the best/safest way to remove the engine from the frame?
I have the head and barrel off but it still seems a very unwieldy lump to lift and clear the frame?
Does it make and difference/help to remove the stator and cover?
Removing engine from frame
- ZedHead
- mick znone
- mick znone
I found it useful to have a platform of the same height as the engine next to the bike. Pallets, stool, pile of bricks with a piece of wood or whatever. Drain the oil and remove the oil filter as this sits low under the engine.
Take the weight with a trolley jack with a short plank of wood under the engine. Undo the engine bolts and remove. Jack it up a little, then you can Manoeuvre/manhandle it onto the platform without having to actually pick it up.
Worked for me
Worked for me
1976 KZ900
1976 KZ900
