I need a No. 3 Mikuni 28mm carb has anyone out there got a spare they would sell me .
The carbs on my project had a repair on one of the posts that support the float. Tonight this repair gave out..
28mm mikuni carb
28mm mikuni carb
Z1000 MK2
Z1300 DFI
Z1300 DFI
Roger Hill wrote:Hi Gavin
Did you get fixed up with a carb ?
What spec is it you require ?
I have a used bare carb body if it is of any use to you.
It is the late Z1A/Z1B type that uses the float bowl with the small brass drain screw not the large bung in the bottom.
Let me know if it is the type you need.
Roger
Cleggy has set me up with a set of Z900 A4 carbs
Looking at other carbs they may not be Kawasaki carbs.
Thanks for the help
Z1000 MK2
Z1300 DFI
Z1300 DFI
Gavin wrote:Roger Hill wrote:Hi Gavin
Roger
Thanks for the help
Further to this post the z900 A4 carbs Cleggy set me up with was missing the tickover adjust screw, I managed to source a NOS screw, actually I got 2 of them. The 2nd will be going up on the for sale section soon.
Z1000 MK2
Z1300 DFI
Z1300 DFI
