Front brake master cyl. What size circlip pliers ?
I have a few front brake master cylinders to overhaul but what size/type of circlip pliers do I need ?? There isn't much space down there!
Recommendations and where to buy info appreciated
Thanks.
Thanks.
- wheelysteve
I managed to break off one of the eyes at the end of the cir clip so be careful.
There is a lot of spring pressure to release while your face is looking straight at the piston waiting to escape when the cir clip is released
Anyone know how to get the circlip out with one end missing?
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- ZedHead
These look like they will do the job
http://www.bikerstoolbox.co.uk/acatalog ... nners.html
Bottom of the page
Bottom of the page
circlip pliers
http://www.bikerstoolbox.co.uk/acatalog/info_L4739.html
These are the best tool for the job. Worth every penny.
- wheelysteve
I'm seeing if I can rescue this original Tokico master cyl to replace the repro one on the bike. Trying to get it to bits to see what condition the bore is in.
Can they be over bored to 5/8th size and still be used on a single disc set up?
If so, any recommendations for the work?
Thanks, Steve
Thanks, Steve
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
wheelysteve wrote:I'm seeing if I can rescue this original Tokico master cyl to replace the repro one on the bike. Trying to get it to bits to see what condition the bore is in.
Thanks, Steve
I had a problem with a brake cylinder on a car, actually part of a remote servo. I managed to get it apart but the bore was pitted, so unusable. I had it bored out then had a stainless steel liner fitted. Our car club has this done, so I wouldn't be able to suggest a company to do it, but may well worth a look around.
Richard
1976 KZ900
1976 KZ900
- ZedHead
Thanks, Steve
Yes they can be over bored to 5/8th and would still be usable on a single disc, any engineering shop should be able to do this, there is a bloke called Mark Hutton based near Liphook who was doing this refurb. I don't have his number but if you contact Guy the area rep. he may be able to tell you as I think he had his done, I would suggest that if Mark Hutton does the job it would be spot on.
You'll have to pull the broken circlip inwards by the remaining eye and get a flat blade screwdriver behind it as soon as there is a gap and pry it out that way.
One of the problems of using circlip pliers like the ones shown is that the point is very fine and would put pressure on a smaller area of the eye therefore more likely to snap it, if the actual jaw fits in the eye they would be great, that's why I use long nose pliers rather than circlip pliers, as for the first ones I use them when I go fishing.
- wheelysteve
Thanks Steve,
I was using long nose pliers to try to get the circlip out when the eye snapped off. I'm a bit wary of the whole piston and spring firing out and hitting me in the face when trying to force it with a screwdriver etc !
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- ZedHead
I've had this problem for years, purchased numerous pairs. I've never been able to get the pair like they illustrate in the workshop manual, it has a pantograph type action that reaches further into the cylinder end.
I now just give them to a mate who uses a scriber and "presto" out comes the circlip. It is an art!
This process is not unlike the time I refused to remove an 8 mm headed bleed screw from a bike as I was sure it would break off. Another guy came along and removed it with ease. The trick was to tighten the screw first!
- wheelysteve
In the end I used a scriber and small screwdriver along with a bit of force and the circlip came out ok. The piston is a bit corroded but the bore of the m/c looks unarmed so I'm hoping to rescue it as it is.
I believe these were anodised satin black originally (now an odd purply colour). Can they be re-anodised or is painting the way to go? Does the brake fluid not destroy and type of spray paint put on?
Cheers, Steve
Cheers, Steve
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Users browsing this forum: zed9 and 71 guests
