z1100st A1 (re - birth) lots of pics?
freddyz1r
#91 PostAuthor: freddyz1r » Fri Mar 13, 2015 8:32 pm
Found theses little half moon things, better bag them
freddyz1r
PUM 329
freddyz1r
#92 PostAuthor: freddyz1r » Fri Mar 13, 2015 8:36 pm
Oops, side tracked :shock:
back to releasing the crank
put the bits in the box :wink:
freddyz1r
PUM 329
freddyz1r
#93 PostAuthor: freddyz1r » Fri Mar 13, 2015 8:37 pm
Cases empty (ish)
freddyz1r
PUM 329
freddyz1r
#94 PostAuthor: freddyz1r » Sun Mar 15, 2015 10:54 am
My pictures have got a bit jumbled so forgive me if they flick backwards and forwards slightly :oops:
looking at the crank cases , I keep noticing more locating dowels and more o rings :shock:
I think I've got most of them out now, but some of the dowels just don't want to budge :cry:
I don't want to get all 'medieval' on them, so have decided to leave the couple that I can't shift :??
freddyz1r
PUM 329
freddyz1r
#95 PostAuthor: freddyz1r » Sun Mar 15, 2015 11:07 am
The selector forks etc was the last things to come out of the cases.
the mechanics of them looked quite daunting :??
(I now know that I have 'lost' all my photos of the forks internally, as I was removing them.
I only have the external photos :oops: that'll be a problem later :cry: )
Trying to see how all this worked /came apart was a real test, and to ME it has been the hardest part of the strip down so far( too many parts in direct interaction with each other, and in such a confined space).
freddyz1r
PUM 329
freddyz1r
#96 PostAuthor: freddyz1r » Sun Mar 15, 2015 11:08 am
Noticed this spring loaded arm sits in a 'gauged' out area.
freddyz1r
PUM 329
freddyz1r
#97 PostAuthor: freddyz1r » Sun Mar 15, 2015 11:17 am
Tried to take pictures of everything as it came out, how it came out etc etcImageImageImageImage
and of course what it looks like when it's out on the table :roll:
freddyz1r
PUM 329
freddyz1r
#98 PostAuthor: freddyz1r » Sun Mar 15, 2015 8:42 pm
If you cast your mind back, I found some shards of something in the sump, that resembled 'bakerlite' :shock: further investigation found this
it is some sort of 'resin' / filler.
It has been used to repair the back of a thread in the casing
the bolt actually still pulls tight :shock:
freddyz1r
PUM 329
freddyz1r
#99 PostAuthor: freddyz1r » Sun Mar 15, 2015 8:58 pm
Started looking at the head and the stripped threads.
realised that 3 or maybe 4 have already had an insert / 'helicoil' fitted.Image
highlighted the openings that need attention :cry:
I'll try and get it dropped off at 'mansfield engines' in the week and let the "professionals"
repair the threads :wink:
freddyz1r
PUM 329
freddyz1r
#100 PostAuthor: freddyz1r » Mon Mar 16, 2015 9:46 am
Started getting a few bits ready for polishing, you may recall I had a play with my new blasting cabinet :shock: thd effect on the ally foot peg hangers was spot on :up
this was the pics of the 2 foot peg hangers. The thick black paint came off a treat on the 1 I'd already tested :) it even left the 'nobly' finish which it's supposed to be. Just needed a bit more work.
freddyz1r
PUM 329
freddyz1r
#101 PostAuthor: freddyz1r » Mon Mar 16, 2015 9:59 am
First thing, I had to remove or mask the black disc (surround for the centre stand lock).
It turned out not to be a decal/sticker :clap
so i was able to remove it whole. (It's not in bad shape and I could re-use it, but I think if they are still available somewhere ((depending on price :oops: )) I will replace it).
The after effect of removing the thick black paint is very good, the hangers should polish up nice :wink:
freddyz1r
PUM 329
freddyz1r
#102 PostAuthor: freddyz1r » Tue Mar 17, 2015 6:29 am
Took my frame and a load of other parts round to the blasters/ powder coaters.
seeing as I'm not trying to build a 'rivet counters dream' :shock: :lol: I decided on everything going a shade of gloss black (there are 12 basic shades of gloss black alone :?? )
if I'm honest my head was spinning :star (have you ever heard of too much choice :?: ).
Anyways I took lots of pics before I dropped everything off and listed every part, heres just a couple ( are you getting bored of all the low quality photography yet :?: ). I'll do a comparison after friday when I pick it all back up.ImageImageImage
cheerz freddy :D
freddyz1r
PUM 329
freddyz1r
#103 PostAuthor: freddyz1r » Tue Mar 17, 2015 7:10 am
When I dropped the cylinder head off, the guy pointed out a couple of potential problems :shock:
I've tried to highlight 1 off them (zoom in) using photobucket :wall. I admit I'm crap :turd at this photos malarkey.
theres hardly anything left on the outside part of the head (it's been opened out that much already, that a tiny piece has dropped off :bawl ),he has suggested drilling out the remaining thread, inserting a piece of bar, welding it into place, filing / shaping the outside and re-drilling and tapping back to (I think M6) size. :hot
I SAID YES :tick
anyways it should be done for the close of play on friday :lol:
freddyz1r
PUM 329
freddyz1r
#104 PostAuthor: freddyz1r » Tue Mar 17, 2015 7:15 am
How come my pics look so large on here?
Do I need to 'crop' each 1 or something?
Cheerz freddy :D
(don't forget you are explaining to the 'technically challenged' :fou )
freddyz1r
PUM 329
#105 PostAuthor: Pigford » Tue Mar 17, 2015 7:23 am
freddyz1r wrote:How come my pics look so large on here?
Cheerz freddy :D
You can resize them on your "host" ... photobucket, etc :wink:
