z900 a4 tyres
avon rooad rider tyre
[quotewot pre="njwmct"]Avon AM26 Roadriders[/quote] wot tyre presures
Thanks,
John
John
chrisu wrote:don't use the original recommended tyre pressures if you put modern tyres (e.g. BT45s) on. they'll be too low.
use 2.5 bar front and 2.6 bar in the rear. Or 32/38 in PSI terms.
Agree on first sentence. 32/38 does sound high tho' - what does it go up to when bike is fully loaded
Pigford wrote:chrisu wrote:don't use the original recommended tyre pressures if you put modern tyres (e.g. BT45s) on. they'll be too low.
Its what Bridgestone recommend and its been fine for me....
but hey normally just me on the bike not 2 up with a shed load of camping gear etc.
Depends how heavy you are ?
ADRIAN H wrote:Pigford wrote:chrisu wrote:don't use the original recommended tyre pressures if you put modern tyres (e.g. BT45s) on. they'll be too low.
Ahhhh, thats why it sounds a lot then
Users browsing this forum: No registered users and 145 guests
