z1100st A1 (re - birth) lots of pics?
freddyz1r
#106 PostAuthor: freddyz1r » Tue Mar 17, 2015 7:28 am
Do I have to alter each 1 individually?
What size are they supposed to be?
Cheerz freddy :D
freddyz1r
PUM 329
freddyz1r
#107 PostAuthor: freddyz1r » Wed Mar 18, 2015 7:05 am
Well I've tried to 'resize' :roll:
having to alter each 1 individually in 'photobucket'. Every time I alter 1, click on the next pic and the sizing as referred back to original 1024 x 768:oops:
must be an easier way than doing every photo individually :??
Cheerz freddy :D
freddyz1r
PUM 329
freddyz1r
#108 PostAuthor: freddyz1r » Wed Mar 18, 2015 7:25 am
Getting back on with the project thread :shock: and catching up on here;
Made a start on the brakes, rear first.
It tried to commit suicide on me :cry: (makes the strip down easier, if everything fell apart :lol:) Even the springs surrounding the brake pipes have snapped through corrosion :|
It's mainly just a build up of crud, through years of leaking and not being used :shock:
(Being a 'gimp' ((wheres my mask :?: )) if you see me using the back brake it's probably too late to stop :shock:)ImageImage
freddyz1r
PUM 329
freddyz1r
#109 PostAuthor: freddyz1r » Wed Mar 18, 2015 7:36 am
This 'linkage' rod is totally corroded and worn out :x , I don't think it'll survivd a turn in the blaster :evil:
freddyz1r
PUM 329
freddyz1r
#110 PostAuthor: freddyz1r » Wed Mar 18, 2015 10:54 am
The rear master cylinder thingy is particularly fu**ed (industry term). I am at present unable to take it apart :grr. The 'retaining clip' looks like it has totally corroded into place :oops:
I have stood it up to soak in wd40 for a couple of days, this has had no effect :cry:
Can this be drilled out to take the replacement /repair kit :?:
or do I need a complete replacement :?:
freddyz1r
PUM 329
freddyz1r
#111 PostAuthor: freddyz1r » Wed Mar 18, 2015 11:07 am
Pushed the piston back with my trusty g clamp (had it man and boy :lol: )
Went back nice and smooth :D not going to take the piston out, unless I have too.
prepared caliper for blasting (don't want any 'media' getting behind the piston)
freddyz1r
PUM 329
freddyz1r
#112 PostAuthor: freddyz1r » Wed Mar 18, 2015 11:20 am
Needed to strip the rear caliper hangerImage
I knew I kept some imperial spanners for something :lol: this 9/16th spanner fits nicely under the slider for levering out :wink: Image
the right hand side 1 is a different 'slider', I didn't know that :oops: . It must be the 'plastic sleeve' that makes it 'tight' :?: :?:
all the bolts and bits removed another thing ready for the blaster :twisted:
freddyz1r
PUM 329
Hinckley
#113 PostAuthor: Hinckley » Wed Mar 18, 2015 11:56 am
Good work so far Freddy :up
The circlip in the master cylinder is steel - the cylinder is aluminium - with enough persuasion it will yield.
Both the steel and aluminium have corroded, the mixed corrosion reacts and sets like concrete - but is not as strong as it looks - I have had success using a hammer and old screwdriver to chisel it away.
Replacement is easier - if you can get one.
freddyz1r
#114 PostAuthor: freddyz1r » Wed Mar 18, 2015 12:24 pm
Thanks for that alex, I'll try and get it out later :?? ( I'm usually quite good at 'brute force and ignorance' :lol: ) I know I don't have a spare of those and I'm up for a little challenge.
cheerz freddy :D
freddyz1r
PUM 329
freddyz1r
#115 PostAuthor: freddyz1r » Wed Mar 18, 2015 8:24 pm
Next job was to remove the rear disc. Other than a minor amount of rust (just surface) it's in near perfect condition,hardly any scores, it's had no use :shock:
However, these disc bolts were well and truly in there :evil: a right bas**ad (industry term) to get out.
An almost full arsenal was required to make the stubborn buggers shift (can't wait for double the amount on front wheel :no )
Lots of heat, numerous different types of allen keys, an hammer, an improvised lever bar and old 'dewalter' set on hammer.
freddyz1r
PUM 329
freddyz1r
#116 PostAuthor: freddyz1r » Wed Mar 18, 2015 8:46 pm
Mini party time when yhe disc was off :hoo (I can be easily pleased :lol:)Image
some of the allen keys didn't fare too well :oops:
to say they got a good hammering is an understatement :shock:
(Hey, needs must and most of them were 'mickey mouse tools', just a bit pi**ed about my 'mac' one :cry: )
These 3 hit the bin straight away :lol:
freddyz1r
PUM 329
Z1parR
#117 PostAuthor: Z1parR » Wed Mar 18, 2015 8:59 pm
It's quite clear that as a tight arse you will not spend money on the correct tools .
However i'm quite prepared to loan you my factory toolkit for working on zeds .
These have always worked fine for most jobs i've done on my bikes .
There's no need for thanks , i'm happy to help a mate out :up
0172 . Geoff Parr
freddyz1r
#118 PostAuthor: freddyz1r » Wed Mar 18, 2015 9:27 pm
Well geoff, if you are passing could you please drop in the grinder, I'm sure that could prove useful :lol: :wink:
Cheerz freddy :D
Something you've never heard before:-
"Why's yours bigger than mine :?: " :shock:
freddyz1r
PUM 329
freddyz1r
#119 PostAuthor: freddyz1r » Wed Mar 18, 2015 9:46 pm
Next, started on the front brakes
stripped the caliper hanger, the rubber/plastic sleeve is on one of the sliders again. It must be the norm :P
freddyz1r
PUM 329
needaz1100r
#120 PostAuthor: needaz1100r » Thu Mar 19, 2015 7:44 am
Hinckley wrote:Good work so far Freddy :up
Hinckley is right, they do almost always come out, the problem with a replacement is they are all the same age and sat in the same place on the same bikes for the same length of time, so you can't guarantee the replacement is any better, not unless you have the time to drive up and down the country inspecting them before you buy.
Countless times I've bought a 'better' part than mine on ebay only to throw it in the bin as soon as it arrives.
Mark.
